    sounds familiar? undici
    4 Posts 2 Posters 1.1k Views 2 Watching
      ReD1470
      A JavaScript error occurred in the main process
      0|mm | Uncaught Exception:
      0|mm | Error: Cannot find module ‘undici’
      so after updateing the mirror and the pi this is my error
      I have rebooted and have ran sdetweil fix-it-all script with apply.
      But helas…
      Mirror down mayday mayday
        sdetweil @ReD1470
        @ReD1470 you did not update to the required nodejs version…
        if you had run the automated ugrade script it would have handled this for you
        depending on your OS version you ‘might’ be able to force fix it
        run the upgrade script from above with
        force
        at the end, instead of
        apply
          ReD1470
          So I ran the script, again, only now I applied FORCE at teh end
          result:
          ebian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
          permitted by applicable law.
          Last login: Mon Jan 13 16:27:51 2025 from 192.168.2.127
          pi@pi-mirror:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” force
          update log will be in /home/pi/MagicMirror/installers/upgrade.log
          doing test run = false
          Node currently installed. Checking version number.
          Minimum Node version: v20.18.1
          Installed Node version: v20.18.1
          Check current Node installation …
          No Node.js upgrade necessary.
          Check current NPM installation …
          NPM currently installed. Checking version number.
          Minimum npm version: V10.8.2
          Installed npm version: V10.8.2
          No npm upgrade necessary.
          want /var/swap=200MByte, checking existing: keeping it
          saving custom.css
          upgrading from version 2.30.0 to 2.30.0
          fetching latest revisions
          updating MagicMirror runtime, please wait
          the screen did not change, so i pressed enter, and new info came up.
          magicmirror@2.30.0 postinstall
          npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
          magicmirror@2.30.0 install-vendor
          echo "Installing vendor files …
          " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
          changed 3 packages in 11s
          magicmirror@2.30.0 install-fonts
          echo "Installing fonts …
          " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
          Installing fonts …
          changed 2 packages in 7s
          then it started checking all my modules, no changes there
          But all is well again and the mirror is running
          So again Sam, tnx a milion!
          2bad i keep running into these errors
            sdetweil @ReD1470
            @ReD1470 this is why i created the upgrade script, cause there lots of little things that will make you unhappy!
            • R ReD1470 has marked this topic as solved on
