    Lost resolution after reboot?!?
    12 Posts 2 Posters 8.6k Views 2 Watching
    • K Offline
      Kai-Christoph
      /opt/vc/bin/tvservice -s
      state 0x120006 [DVI DMT (4) RGB full 4:3], 640x480 @ 60.00Hz, progressive
      That is the resolution shown by the Raspi.
      Slowly I have the feeling like sitting at an Windows-Machine…
      • yawnsY Offline
        yawns Moderator
        Could you try this?
        https://weblogs.asp.net/bleroy/getting-your-raspberry-pi-to-output-the-right-resolution
        • K Offline
          Kai-Christoph
          /opt/vc/bin/tvservice -m CEA
          Group CEA has 2 modes:
                     mode 4: 1280x720 @ 60Hz 16:9, clock:74MHz progressive
                     mode 16: 1920x1080 @ 60Hz 16:9, clock:148MHz progressive
          /opt/vc/bin/tvservice -m DMT
          Group DMT has 1 modes:
            (prefer) mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
          The Mirror worked for mont without any issues…
          • yawnsY Offline
            yawns Moderator
            @Kai-Christoph said in Lost resolution after reboot?!?:
            hdmi_group=2
            means “use DMT”
            hdmi_group=1 would use CEA
            So I would suggest finding out possible modes in CEA and set these in your config.txt
            • K Offline
              Kai-Christoph
              tvservice -d edid
              Nothing written!
              I tried this before…
              edid seems not to work.
              • K Offline
                Kai-Christoph
                Now I tried this, as mentioned here
                hdmi_cvt=1920 1200 60 5 0 0 1
                Nothing happened: The Raspi stucks on 640x480…
                • K Offline
                  Kai-Christoph
                  Man, I could freak out: The HDMI to DVI cable is somehow broken. I replaced it and everything works fine again. I spent hours to solve the problem… F**K!
                  • yawnsY Offline
                    yawns Moderator
                    Oh bad. Good you found it and good it was not fault of Windows … errm Raspbian ;)
