    Lost resolution after reboot?!?
    12 Posts 2 Posters 10.0k Views 2 Watching
    • Y
      yawns Moderator
      Hi. Was your display switched off during reboot? I had that with my tv and follow a small tutorial to save my display settings so the pi does not care if the display is on or off during boot
      • K
        Kai-Christoph
        No, unfortunately the Monitor was turned on. I think there is sth wrong with the settings in /boot/config.txt
        But I can’t figure out, how to fix this.
        • K
          Kai-Christoph
          So, here ist my /boot/config.txt:
          # For more options and information see
          # http://www.raspberrypi.org/documentation/configuration/config-txt.md
          # Some settings may impact device functionality. See link above for details
          # uncomment if you get no picture on HDMI for a default "safe" mode
          hdmi_safe=1
          # uncomment this if your display has a black border of unused pixels visible
          # and your display can output without overscan
          #disable_overscan=1
          # uncomment the following to adjust overscan. Use positive numbers if console
          # goes off screen, and negative if there is too much border
          #overscan_left=16
          #overscan_right=16
          #overscan_top=16
          #overscan_bottom=16
          # uncomment to force a console size. By default it will be display's size minus
          # overscan.
          #framebuffer_width=1280
          #framebuffer_heiframebuffer_width=1080
          #framebuffer_height=1920
          #framebuffer_depth=32
          #framebuffer_ignore_alpha=1
          # uncomment if hdmi display is not detected and composite is being output
          hdmi_force_hotplug=1
          # uncomment to force a specific HDMI mode (this will force VGA)
          hdmi_group=2
          hdmi_mode=69
          # uncomment to force a HDMI mode rather than DVI. This can make audio work in
          # DMT (computer monitor) modes
          hdmi_drive=1
          # uncomment to increase signal to HDMI, if you have interference, blanking, or
          # no display
          #config_hdmi_boost=4
          # uncomment for composite PAL
          #sdtv_mode=2
          #uncomment to overclock the arm. 700 MHz is the default.
          #arm_freq=800
          # Uncomment some or all of these to enable the optional hardware interfaces
          #dtparam=i2c_arm=on
          #dtparam=i2s=on
          #dtparam=spi=on
          # Uncomment this to enable the lirc-rpi module
          #dtoverlay=lirc-rpi
          # Additional overlays and parameters are documented /boot/overlays/README
          # Enable audio (loads snd_bcm2835)
          #dtparam=audio=on
          display_rotate=3
          avoid_warnings=1
          The Samsung Syncmaster 245plus has a native resolution of 1920x1200@60Hz.
          I think the hdmi_group an _mode settings are correct, but it still doesn’t work…
          What is wrong?
          • K
            Kai-Christoph
            /opt/vc/bin/tvservice -s
            state 0x120006 [DVI DMT (4) RGB full 4:3], 640x480 @ 60.00Hz, progressive
            That is the resolution shown by the Raspi.
            Slowly I have the feeling like sitting at an Windows-Machine…
            • Y
              yawns Moderator
              Could you try this?
              https://weblogs.asp.net/bleroy/getting-your-raspberry-pi-to-output-the-right-resolution
              • K
                Kai-Christoph
                /opt/vc/bin/tvservice -m CEA
                Group CEA has 2 modes:
                           mode 4: 1280x720 @ 60Hz 16:9, clock:74MHz progressive
                           mode 16: 1920x1080 @ 60Hz 16:9, clock:148MHz progressive
                /opt/vc/bin/tvservice -m DMT
                Group DMT has 1 modes:
                  (prefer) mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
                The Mirror worked for mont without any issues…
                • Y
                  yawns Moderator
                  @Kai-Christoph said in Lost resolution after reboot?!?:
                  hdmi_group=2
                  means “use DMT”
                  hdmi_group=1 would use CEA
                  So I would suggest finding out possible modes in CEA and set these in your config.txt
                  • K
                    Kai-Christoph
                    tvservice -d edid
                    Nothing written!
                    I tried this before…
                    edid seems not to work.
                    • K
                      Kai-Christoph
                      Now I tried this, as mentioned here
                      hdmi_cvt=1920 1200 60 5 0 0 1
                      Nothing happened: The Raspi stucks on 640x480…
                      • K
                        Kai-Christoph
                        Man, I could freak out: The HDMI to DVI cable is somehow broken. I replaced it and everything works fine again. I spent hours to solve the problem… F**K!
                        • Y
                          yawns Moderator
                          Oh bad. Good you found it and good it was not fault of Windows … errm Raspbian ;)
