    Lost resolution after reboot?!?
    12 Posts 2 Posters 9.0k Views 2 Watching
    • yawnsY Offline
      yawns Moderator
      Could you try this?
      https://weblogs.asp.net/bleroy/getting-your-raspberry-pi-to-output-the-right-resolution
      • K Offline
        Kai-Christoph
        /opt/vc/bin/tvservice -m CEA
        Group CEA has 2 modes:
                   mode 4: 1280x720 @ 60Hz 16:9, clock:74MHz progressive
                   mode 16: 1920x1080 @ 60Hz 16:9, clock:148MHz progressive
        /opt/vc/bin/tvservice -m DMT
        Group DMT has 1 modes:
          (prefer) mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
        The Mirror worked for mont without any issues…
        • yawnsY Offline
          yawns Moderator
          @Kai-Christoph said in Lost resolution after reboot?!?:
          hdmi_group=2
          means “use DMT”
          hdmi_group=1 would use CEA
          So I would suggest finding out possible modes in CEA and set these in your config.txt
          • K Offline
            Kai-Christoph
            tvservice -d edid
            Nothing written!
            I tried this before…
            edid seems not to work.
            • K Offline
              Kai-Christoph
              Now I tried this, as mentioned here
              hdmi_cvt=1920 1200 60 5 0 0 1
              Nothing happened: The Raspi stucks on 640x480…
              • K Offline
                Kai-Christoph
                Man, I could freak out: The HDMI to DVI cable is somehow broken. I replaced it and everything works fine again. I spent hours to solve the problem… F**K!
                • yawnsY Offline
                  yawns Moderator
                  Oh bad. Good you found it and good it was not fault of Windows … errm Raspbian ;)
