    First MM project - family dashboard
    11 Posts 5 Posters 5.3k Views 8 Watching
    • C Offline
      cpcode @raymonvdm
      @raymonvdm Really sorry, I wrote out this whole reply but never hit Submit… Well better late than never:
      MMM-page-indicator by default has a set of little circles at the bottom, one for each page, and they are already clickable. I just turned the little circles into tabs in the HTML - that part was very easy if I remember right.
      There are a bunch of modules that implement hooks for physical GPIO buttons, like MMM-button , MMM-buttons, and others. Some of them probably already have examples to attach the physical button click to page selections.
      • C Offline
        cpcode @rkorell
        @rkorell Thanks! I did end up implementing MMM-MPlayer. It was indeed very easy, but unfortunately it only seems to work some of the time - for the first week, it would work until about 4 pm and then stop. Now it’s not showing up at all. Since it just brings up another process on top of the mirror, I’m not sure how to debug this issue, but I haven’t had time to look at it yet.
        • C Offline
          cpcode @mischag
          @mischag My code is a jumbled mess, has few comments, and only works for the exact combination of modules (public and custom) that I have. If you tell me which parts you are stuck on, or which module changes you are interested in, I’d be happy to send you those pieces or help out as best I can. I can also clean up some of my code and post more forks on GitHub for pieces that may be useful.
          I did use custom.css to modify things, happy to share that too, if you let me know what parts of my setup you are interested in.
            rkorell @cpcode
            @cpcode OK, use it really seldom, so your findings are new to mee…
            Good luck.
            Ralf
            • K Offline
              Kodama666
              Hi there,
              Nice project! I tried a similar one myself but was into abled to get the CPU info running for MMM-Systeminfo. Can you tell me what parameter you used for cpuUsageCommand ?
              Kind regards
              Kodama666
              • C Offline
                cpcode @Kodama666
                @Kodama666 I did not override that setting, actually. This is what my config looks like for MMM-SystemInfo:
                module: ‘MMM-SystemInfo’,
                classes:“System moduleMargins”,
                position: “upper_third”,
                network: “My guest network has another name”,
                password: "Speak, friend, and enter :) ",
                showCpuUsage: true,
                showRamUsage: true,
                showDiskUsage: true,
                showCpuTemperature: true,
                showVolume: true,
                tableClass: ‘medium’,
                qrSize: 220,
                layout: “rtl”,
                The cpu usage worked from the start. However, I did have to override ‘cpuTemperatureCommand’. I did it directly in MMM-SystemInfo.js because I didn’t know any better at the time. This is my new value for it:
                 cpuTemperatureCommand: "echo \"$(( ($(cat /sys/class/thermal/thermal_zone*/temp))))\"",
                I doubt this will help you with cpu usage, but that’s all I modified.
                • K Offline
                  Kodama666 @cpcode
                  @cpcode: Thanks…that did help indeed. I thought that CPUUsage would be displayed by default. I really only needed to set it as true…unfortunately now it only displays either 100 or 50% while htop only measures a few % for each core…CPU Temp displays thanks to your command….and while volume usage should not matter at all it only shows NaN…well…as it is not a productive system in any case and just a fun project i will deal with that as I increase my knowledge :-)
