    MMM-CalendarExt3 always displays previous week
    9 Posts 3 Posters 2.3k Views 3 Watching
      mrsmith81
      I’m using MMM-CalendarExt3 to post our family calendar. I would like to display the current week along with the next 2 weeks. Whenever I set mode to week, the previous week always displays first, no matter what I set the week index to. Is there a setting I’m missing that is over riding this? Thanks for the help.
      • X Offline
        Xsoldier2000 @sdetweil
        @sdetweil said in MMM-CalendarExt3 always displays previous week:
        @Xsoldier2000 @mrsmith81
        weekIndex defaults to -1 (last week)
        sigh, thank you!
          sdetweil @mrsmith81
          @mrsmith81 can you show the ext3 module config
          • X Offline
            Xsoldier2000
            While I’m not OP, I’m having the same issue. My config is below. Today is 1/31, but with the config as is, when I run pm2 start MM, it displays last week (Jan 19th thru the 25th).
            module: “MMM-CalendarExt3”,
            position: “top_bar”,
            title: “”,
            mode: “week”,
            instanceId: “WeekCalendar”,
            weeksInView:1,
            maxEventLines: 6,
            firstDayOfWeek: 0,
            calendarSet: [],
            useWeather: false,
            fontSize: “22px”,
            eventHeight: “26px”,
              sdetweil @Xsoldier2000
              X 1 Reply Last reply Reply Quote 0
                sdetweil @mrsmith81
                @mrsmith81 MagicMirror is case sensitive,
                weekIndex is not the same as weekindex
                • X Offline
                  sigh, thank you!
                    @Xsoldier2000 so you need to put it into the config as 0
                    weekIndex :0,
                      mrsmith81 @sdetweil
                      @sdetweil Thank you! I was out of town so was just home and able to get into the coffee and this is exactly the problem.
                        sdetweil @mrsmith81
                        @mrsmith81 and the fix
