    birthdaylist - discontinued ?
    63 Posts 2 Posters 18.6k Views 2 Watching
      Forgot to include my config but it’s nearly exact clone of yours…
      	        module: "birthdaylist",
      	        disabled: false,
      	        position:'top_right',
      						dimmEntries: false,  // true: dims entries and the associated symbol when the date has expired. false: dont display entries and the associated symbol when the date has expired.
      						initialLoadDelay: 0, // How many seconds to wait on a fresh start up.
      						updateDelay: 5,      // How many seconds after midnight before a refresh
      						currentMonthOnly: false,  // will show birthdays for the current month only if true
      						maxEntries: 3,	     // maximum entries to show, default is all
      						dateFormat: '',	     // date format for birthday (default is none), could be 'Do' for 'Sep 12th'
      						ageFormat:'',	     // some format string for the persons age, '[ n ]'  n will be replace by age value
      						withMonth: true ,    // then true, add the month display as part of the date field,
      						debug:true,
      						debugging:true,
      Yesterday (for some reasons I took a photo) the three (correct) items were displayed on my screen as well…
      But today: nothing…
      really strange - because regarding log messages module is active.
      And I cannot see any reason why it doesn’t show.
      Thats the reason for my question…
      So please ignore this - I will wait an see …
      Thanks a lot again for your kind support on this.
      Ralf
        sdetweil @rkorell
        @rkorell ok, I just fixed a timing problem when resuming (for any reason) and close to refresh time
        git pull to give it a try…
          @sdetweil You are SO hardworking!
          Awesome.
          Thanks.
          The module was visible today in the morning.
          Pulled, anyway:
          remote: Enumerating objects: 5, done.
          remote: Counting objects: 100% (5/5), done.
          remote: Compressing objects: 100% (1/1), done.
          remote: Total 3 (delta 2), reused 3 (delta 2), pack-reused 0 (from 0)
          Unpacking objects: 100% (3/3), 286 bytes | 20.00 KiB/s, done.
          From https://github.com/sdetweil/birthdaylist
             03c25c8..b430432  master     -> origin/master
          Updating 03c25c8..b430432
          Fast-forward
           birthdaylist.js | 4 ++--
           1 file changed, 2 insertions(+), 2 deletions(-)
          Many thanks!
          Regards,
          Ralf
          • 4 / 4
