    Error: Cannot find module 'undici' after update using script from sdetweil
    6 Posts 2 Posters 1.3k Views 2 Watching
    • G Offline
      Gnardar
      Applied the latest update of MM to my rpi4 and am getting the following error when trying to launch MM
      Error: Cannot find module ‘undici’
      Running the script shows the latest nodejs version etc
        sdetweil @Gnardar
        @Gnardar replied
        net, you attempted upgrade manually, and got caught be the node upgrade requirement
        now MagicMirror code is 2.30, node is downlevel
        npm install fails
        then you ran upgrade script, but it will not upgrade same version (without extra step)
        so it made no change, stuck in same spot
        to force upgrade in this situation, change the word apply
        to force on the upgrade command
          sdetweil @Gnardar
          @Gnardar show the rest of the upgrade.log
          • G Offline
            Gnardar @sdetweil
            @sdetweil Are you wanting to see it from when I ran the upgrade or when I run it again to see that it is up to date?
              sdetweil @Gnardar
              @Gnardar where you ran the upgrade, just send the whole file to my email, same userid at gmail
              it didn’t finish for some reason
              • G Offline
                Gnardar @sdetweil
                @sdetweil Sent. Thanks!
                  sdetweil @Gnardar
                  @Gnardar replied
                  npm install fails
