    MMM-RTSPtoWeb on Raspberry Pi OS x86/amd64 version?
    4 Posts 2 Posters 910 Views 2 Watching
      sforza
      Hi,  Magic Mirror fan with rpi 4B here. Using MMM-RTSPtoWeb video module for surveillance pushes the pi to its limits. As I’m planning to add further video streams I’m considering moving to mini pc with Intel N100 processor. Here’s the pros and cons I can think of, please validate or suggest.
      I know this would effectively be an arm to amd64 architecture change. Unsure how OS compatibility and modules will behave. I am aware Raspberry pi OS x86 version exists but it’s different from original arm one.
      Furthermore since MM is rather lightweight for a N100 I was even thinking about installing proxmox and running raspberry pi OS as a VM with hdmi being passed through.
      I guess my question is: would MMM-RTSPtoWeb module work in Raspberry pi OS x86 environment?
      I could always try spinning a VM in proxmox but the time effort is considerable, my proxmox host died recently so need to purchase new ssd and start from scratch. If anyone already knows the answer I’d love to hear from you please.
      Many thanks in advance
      sforza
        sdetweil @sforza
        @sforza the x86 raspios is old, use ubuntu
          sforza @sdetweil
          @sdetweil many thanks for the quick response and tip.
          Should I read your message as MMM-RTSPtoWeb should work just fine with ubuntu? Or can’t really tell unless we test?
          Cheers
            sdetweil @sforza
            @sforza my response is that os is trash. don’t waste time using it.
            no idea what might work from the module perspective , i know there have troubles with RTSP streams in the later os versions
