    MMM-carousel stuck with update
    4 Posts 2 Posters 1.0k Views 2 Watching
    • J
      JMac
      I’m getting this error when running the latest update,
      MagicMirror@raspberrypi:~/MagicMirror/modules/MMM-Carousel $ git pull
      hint: Pulling without specifying how to reconcile divergent branches is
      hint: discouraged. You can squelch this message by running one of the following
      hint: commands sometime before your next pull:
      hint:
      hint: git config pull.rebase false # merge (the default strategy)
      hint: git config pull.rebase true # rebase
      hint: git config pull.ff only # fast-forward only
      hint:
      hint: You can replace “git config” with “git config --global” to set a default
      hint: preference for all repositories. You can also pass --rebase, --no-rebase,
      hint: or --ff-only on the command line to override the configured default per
      hint: invocation.
      Updating fb51858…f14e5e9
      error: Your local changes to the following files would be overwritten by merge:
      package-lock.json
      Please commit your changes or stash them before you merge.
      Aborting
      I’ve tried - git reset package-lock.json
      as was recommended with a similar issue with MMM-CalendarEXT3 but this isn’t offering any steps forward.
      Any thoughts?
      Cheers.
        sdetweil @JMac
        @JMac just
        rm package-lock.json
        then the git pull should work
        J 1 Reply Last reply
        • J
          JMac @sdetweil
          @sdetweil Sorry for the late response, That’s done the job.
          If I get the package-lock.json during any other update, will this work to allow the update to continue?
            sdetweil @JMac
            @JMac yes
