    Weather Module
    7 Posts 2 Posters 1.4k Views 2 Watching
      Sebi76 0
      My Weather does not work. Whats wrong?
      			module: "weather",
      			header: "Wetter",
      			    apiBase: "https://api.openweathermap.org/data/",
       	         	apikey: "xxxxxxxxxxxxxxxxxxxxxxxxx", //Home_MM Api
       	         	locationID: "2876865",
       	      	    lat: 51.676380,            //number works here
       	      	    lon: 8.346650,          //so does a string
       	      	    weatherEndpoint: '/onecall',
      				type: "current",
      				apiVersion: '3.0'
        sdetweil @Sebi76 0
        @Sebi76-0 misspelled
        apikey
        should be
        apiKey
        MagicMirror is case sensitive
          sdetweil @Sebi76 0
          @Sebi76-0 did you get the new apikey? requires a credit card
          also see
          https://forum.magicmirror.builders/topic/19323/version-2-30-0-weather-module-stuck-loading-worked-fine-before-upgrade
            Sebi76 0 @sdetweil
            Yes.
            It works with MMM-OpenWeatherMapForecast, but not with the regular Weather Module
              sdetweil @Sebi76 0
              @Sebi76-0 ok, take off the apibase, endpoint options
              start MagicMirror like this
              npm run start:dev
              in the developers window console tab, put weath in the filter field and see if there are any errors reported
                Sebi76 0
                This is an Error
                weather.js:164 New weather information available.
                weather.js:169 Uncaught (in promise) TypeError: Cannot read properties of null (reading 'replace')
                    at Class.updateAvailable (weather.js:169:106)
                    at Class.updateAvailable (weatherprovider.js:104:17)
                    at openweathermap.js:47:24
                    at <anonymous>
                updateAvailable @ weather.js:169
                updateAvailable @ weatherprovider.js:104
                (anonymous) @ openweathermap.js:47
                  sdetweil @Sebi76 0
                  apikey
                  should be
                  apiKey
                    Sebi76 0
                    i julaughingst . Youre Right!Thanks. Little Misstakes
