    Cannot find module 'request'
    4 Posts 3 Posters 742 Views 3 Watching
      rune
      Hi all!
      I’m using the docker solution for MagicMirror, running in Electron “mode”. Several modules that require fetching content seems to be relying on the “Request” NPM package. This is not installed in the docker MagicMirror package/solution.
      I’ve tried installing the package in the “mm” container, using npm install request - that did not resolve the issue.
      I was hoping someone should have a tip or two for me. Anyone had this issue before. Could not find anything in the forum.
      Thanks for any help!
      Cheers!
      Rune
      • karsten13K Offline
        karsten13 @sdetweil
        https://khassel.gitlab.io/magicmirror/docs/faq.html#error-cannot-find-module-request
          sdetweil @rune
          @rune so you need to do that IN the module folder in the container
          on the docker host
          docker exec -it mm bash
          cd modules/modulename
          npm install request
          cd ../othermodulename
          npm install request
          exit
            karsten13 @sdetweil
              rune @karsten13
              @karsten13 Thanks! That worked! Somehow I missed that FAQ :)
              Rune
