    MagicMirrorOS build intermittently not starting mm container (Version 2.30)
    23 Posts 3 Posters 4.1k Views 3 Watching
      scottwalsh @sdetweil
      @sdetweil said in MagicMirrorOS build intermittently not starting mm container (Version 2.30):
      @scottwalsh please dont double post
      Apologies, user error.
        sdetweil @scottwalsh
        @scottwalsh how big is the swap file?
        free -m
        will tell you
        S karsten13K 2 Replies Last reply Reply Quote 0
          free -m
          scottwalsh@calendar:~ $ free -m
                         total        used        free      shared  buff/cache   available
          Mem:             425         210          66           0         204         214
          Swap:           1023         203         820
            sdetweil @karsten13
            @karsten13 @scottwalsh
            bookworm is about 500m bigger that bullseye
            so swap is critical on small memory machines
            • karsten13K Offline
              karsten13 @sdetweil
              mmos is critical with pi zero 2w, I had a user who gave up, but it depends on installed modules and quality of used sd-card.
              CONF_SWAPSIZE=1024 (if not changed by user)
                @scottwalsh can you show w MagicMirror running…
                  scottwalsh
                  An observation, if I power cycle the pi, there is a good chance of it not starting up with the errors in the original post.
                  Once leave it for five min for all the processes to start (and fail), then run docker compose up -d --force-recreate, it seems to be stable from then on and works well.
                    scottwalsh@calendar:/opt/mm/run $
                    scottwalsh@calendar:/opt/mm/run $ docker compose up -d --force-recreate
                    [+] Running 5/5
                     ✔ Container watchtower  Started        42.0s
                     ✔ Container labwc       Started        41.9s
                     ✔ Container init        Started        42.2s
                     ✔ Container mmpm        Started        42.4s
                     ✔ Container mm          Started        5.3s
                    scottwalsh@calendar:/opt/mm/run $ docker ps
                    CONTAINER ID   IMAGE                          COMMAND                  CREATED         STATUS                   PORTS        NAMES
                    a1cb1b400de1   karsten13/mmpm:latest          "/home/node/entrypoi…"   3 minutes ago   Up 2 minutes             0.0.0.0:6789->6789/tcp, :::6789->6789/tcp, 0.0.0.0:7890-7891->7890-7891/tcp, :::7890-7891->7890-7891/tcp, 0.0.0.0:8907->8907/tcp, :::8907->8907/tcp   mmpm
                    f7ec5d32f0bd   karsten13/magicmirror:latest   "/usr/bin/tini -- ./…"   3 minutes ago   Up About a minute        mm
                    74193ae14fbf   karsten13/labwc:latest         "/entrypoint.sh"         3 minutes ago   Up 2 minutes        labwc
                    bcf30cd7bb10   containrrr/watchtower:latest   "/watchtower --inter…"   3 minutes ago   Up 2 minutes (healthy)   8080/tcp        watchtower
                    scottwalsh@calendar:/opt/mm/run $ free -m
                    Mem:             425         236         134          36         141         189
                    Swap:           1023         296         727
                      @scottwalsh probably swap file speed bound
                        @scottwalsh
                        the script /opt/mm/install/install.sh is executed with every reboot.
                        As workaround you could add
                        sleep 10s
                        at the end (where you have to play with the sleep seconds).
                        • 2 / 3
