    MMM-ISS by daterell
    5 Posts 2 Posters 552 Views 2 Watching
    • N Offline
      Nidra57
      I tried to install the module , but I don’t get any data on my mirror, just “Next ISS fly over”, “Visible”, “Max Height” “Appears” and “Disappears”. Has anyone have suggestions to solve this?
        module: 'MMM-ISS',
        position: 'bottom_right',
          // These values must come from available locations on the SpotTheStation site: https://spotthestation.nasa.gov/
          country: "Netherlands",
          region: "Flevoland",
          city: "Almere",
          minElevation: 40 // 40 Lowest elevation for the panel to show up
      • N Offline
        Nidra57 @Nidra57
        Nidra57
        Oorzaak:
        NASA heeft SpotTheStation op 12 juni 2025 offline gehaald, waardoor alle MMM-ISS installaties wereldwijd niet meer werken.
        Oplossing:
        • gratis N2YO API-sleutel aanvragen op n2yo.com/api
        • node_helper.js herschreven om de N2YO API te gebruiken — zonder dat de rest van de module aangepast hoeft te worden.
        Config.js:
          module: "MMM-ISS",
          position: "bottom_right",
            apiKey: "JOUW_N2YO_SLEUTEL",   // ← nieuw
            lat: 52.37,
            lng: 5.22,
            units: "km",
            minElevation: 40
            // country, region en city zijn niet meer nodig
        Node helper.js:
        /* Magic Mirror
         * Node Helper: MMM-ISS
         * By Dave Terrell
         * MIT Licensed.
         * Modified to use N2YO API instead of NASA SpotTheStation
         * (SpotTheStation was shut down on June 12, 2025)
         * Requires a free N2YO API key from https://www.n2yo.com/api/
         * Add `apiKey: 'YOUR_KEY'` to your module config in config.js
        let NodeHelper = require('node_helper');
        const https = require('https');
        // ISS NORAD satellite ID
        const ISS_ID = 25544;
        // Compass directions lookup
        const DIRECTIONS = [
          'N', 'NNE', 'NE', 'ENE',
          'E', 'ESE', 'SE', 'SSE',
          'S', 'SSW', 'SW', 'WSW',
          'W', 'WNW', 'NW', 'NNW'
        function degreesToCompass(deg) {
          return DIRECTIONS[Math.round(deg / 22.5) % 16];
          requestInFlight: false,
          getData: function (config) {
            if (this.requestInFlight) return;
            this.requestInFlight = true;
            if (!config.apiKey) {
              console.error('MMM-ISS: No N2YO API key set. Add `apiKey: "YOUR_KEY"` to your config.');
              this.sendSocketNotification('ERROR', 'No API key');
              this.requestInFlight = false;
              return;
            let lat = config.lat || 52.37;
            let lng = config.lng || 5.22;
            let alt = config.alt || 0;
            let days = config.days || 10;
            let minElevation = parseInt(config.minElevation) || 40;
            // N2YO visual passes endpoint
            let url = `https://api.n2yo.com/rest/v1/satellite/visualpasses/${ISS_ID}/${lat}/${lng}/${alt}/${days}/${minElevation}/&apiKey=${config.apiKey}`;
            let self = this;
            https.get(url, (res) => {
              let data = '';
              res.on('data', chunk => data += chunk);
              res.on('end', () => {
                try {
                  let json = JSON.parse(data);
                  if (!json.passes || json.passes.length === 0) {
                    console.log('MMM-ISS: No passes found.');
                    self.sendSocketNotification('DATA_RESULT', {});
                  } else {
                    let result = self.parsePass(json.passes[0]);
                    self.sendSocketNotification('DATA_RESULT', result);
                } catch (e) {
                  console.error('MMM-ISS: Error parsing N2YO response:', e);
                  self.sendSocketNotification('ERROR', e.message);
                self.requestInFlight = false;
            }).on('error', (err) => {
              console.error('MMM-ISS: HTTP error:', err);
              self.sendSocketNotification('ERROR', err.message);
          socketNotificationReceived: function (notification, payload) {
            if (notification === 'GET_DATA') {
              this.getData(payload);
          parsePass: function (pass) {
            // N2YO returns Unix timestamps (UTC)
            let startTime = new Date(pass.startUTC * 1000);
            let duration = Math.round(pass.duration / 60); // seconds → minutes
            let durationStr = duration < 1 ? '<1 min' : duration + ' min';
            return {
              date: startTime.toLocaleDateString([], { weekday: 'short', month: 'short', day: 'numeric' }),
              time: startTime.toLocaleTimeString([], { hour: '2-digit', minute: '2-digit' }),
              visible: durationStr,
              maxHeight: pass.maxEl + '°',
              appears: pass.startEl + '°',
              appearsDirection: degreesToCompass(pass.startAz),
              disappears: pass.endEl + '°',
              disappearsDirection: degreesToCompass(pass.endAz),
          sdetweil @Nidra57
          @Nidra57 please , code block around config, log, js
          There could be errors shown in the place you start MagicMirror
          If pm2, then
          pm2 logs —lines=xxxx
          Where xxxx is the count of most recent lines, default 15
            sdetweil @Nidra57
            @Nidra57 this module is broken, a pull request was posted to fix it, but not merged
            I see you opened the PR
            • N Offline
              Nidra57
              Hi @sdetweil, yes that’s correct — I opened the PR myself after figuring out that SpotTheStation was shut down in June 2025.
              The fix replaces the old RSS feed from SpotTheStation with the N2YO API. The module is already working again on my own MagicMirror with the updated node_helper.js. I’ve also updated the README and fixed the default coordinates as requested by @daterrell.
              The PR is now awaiting merge: https://github.com/daterrell/MMM-ISS/pull/8
