    Send Notifications from Linux/RPi Command Line
    8 Posts 2 Posters 1.3k Views 2 Watching
      raspberrypi9
      Is there a module that will allow you to type a notifcation and payload into the linux command line and broadcast it to all of the mirror modules?
      If not, I would like to write one. What would be the architecture that I would need on the mirror side? Can I write a new module that listens on an external socket and connect to that socket with some command line program that I would code?
        sdetweil @raspberrypi9
        @raspberrypi9 see MMM-CommandToNotification
        https://github.com/Tom-Hirschberger/MMM-CommandToNotification
        search the 3rd party list linked above in the top menu
          @raspberrypi9 yes, you can listen to socket, you can also read file.
          i think the one i suggested is not arbitrary timed event
          if you use the room prefix, you can use the same port as MagicMirror
            @raspberrypi9 on the other hand, if you make it post to url, then one could use curl to post it, you wouldn’t have to write a client
            post json { “notification”:“value”, “payload”:{ etc }}
              @raspberrypi9 here you go
              https://github.com/sdetweil/MMM-CurlToNotification
                raspberrypi9
                Sam, I love this! It is exactly what I was looking for and very useful. Thanks so much for making it!
                S 2 Replies Last reply Reply Quote 1
                  @raspberrypi9 i didn’t mean to steal your thunder tho
                    @raspberrypi9 and curl can send a whole file of json, not just a short blob
