    Calendar error ext3 and ext3agenda
    3 Posts 2 Posters 764 Views 2 Watching
      svencarree
      Hello on this beautiful sunday,
      I’ve problems with de Calendar -> ext3 not showing any results. In the past it worked fine but after a fresh install I can’t get it to work. The normal calendar shows the Google agenda fine and this is my code without the correct ICS reference.
      /* Config Sample
       * see https://docs.magicmirror.builders/configuration/introduction.html
       * and https://docs.magicmirror.builders/modules/configuration.html
       * You can use environment variables using a `config.js.template` file instead of `config.js`
       * which will be converted to `config.js` while starting. For more information
       * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
      let config = {
      	address: "localhost",	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
      	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
      	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
      	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
      	language: "nl",
      	locale: "nl-NL",   // this variable is provided as a consistent location
      			   // it is currently only used by 3rd party modules. no MagicMirror code uses this value
      			   // as we have no usage, we  have no constraints on what this field holds
      			   // see https://en.wikipedia.org/wiki/Locale_(computer_software) for the possibilities
      	timeFormat: 24,
      	units: "metric",
          module: "alert",
          module: "updatenotification",
          position: "top_bar"
          module: "clock",
          position: "top_left"
      			header: "Kalender",
      				broadcastPastEvents: true,
      						symbol: "calendar-check",
      						url: "https://calendar.google. ***",
      					color: "Purple"
        module: "MMM-CalendarExt3",
        position: "bottom_bar",
        title: "Familie",
          mode: "week",
          instanceId: "basicCalendar",
          locale: 'nl-NL',
          maxEventLines: 8,
          weekIndex: 0,
          firstDayOfWeek: 1,
          calendarSet: ['Familie Carree'],
          module: "MMM-CalendarExt3Agenda",
          header: "De Agenda",
            locale: "nl-NL",
            firstDayOfWeek: 1,
            startDayIndex: 0,
            endDayIndex: 7,
            calendarSet: ["Familie"],
            listenEventBroadcast: true,
            maxItems: 10,
            showDescription: true,
            showTime: true,
            defaultSymbol: "calendar-check"
        sdetweil @svencarree
        @svencarree did you put on the clipping fix?
          @svencarree did you get this working
