    MMM-WeatherBackground crashing?
    7 Posts 2 Posters 996 Views 2 Watching
      MrCoads
      Hi everyone!
      I’d like to get some help with my MagicMirror MMM-WeatherBackground issue. Occasionally my MagicMirror crashes and is showing a black screen with the cursor.
      I’ve been trouble shooting this issue, but no luck.
      I’ve been disabling various modules to get to the bottom of this, and eventually it was the WeatherBackground causing the issue. I’ve disabled this function and it’s been up and running perfectly fine for the past week. Before it would cash multiple times a day.
      I’m using the RaspBerry Pi Model 3B+ with the following config.js:
      GNU nano 7.2                                  MagicMirror/config/config.js *
            /* Config Sample
             * see https://docs.magicmirror.builders/configuration/introduction.html
             * and https://docs.magicmirror.builders/modules/configuration.html
             * You can use environment variables using a `config.js.template` file instead of `config.js`
             * which will be converted to `config.js` while starting. For more information
             * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
            let config = {
                    address: "localhost",   // Address to listen on, can be:
        // - "localhost", "127.0.0.1", "::1" to listen on loopback inte>
        // Default, when address config is left out or empty, is "local>
                    port: 8080,
                    basePath: "/",  // The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
        // you must set the sub path here. basePath mus>
                    ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],  // Set [] to allow all IP addresses
        // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::>
        // or IPv4 range of 192.168.3.0 --> 192.168.3.1>
            useHttps: false,                        // Support HTTPS or not, default "false" will use HTTP
            httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
            httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
            language: "nl",
            locale: "en-US",   // this variable is provided as a consistent location
                               // it is currently only used by 3rd party modules. no MagicMirror code uses this value
                               // as we have no usage, we  have no constraints on what this field holds
                               // see https://en.wikipedia.org/wiki/Locale_(computer_software) for the possibilities
            timeFormat: 24,
            units: "metric",
                            module: "clock",
                            position: "top_center",
                            showDate: true,
                            showWeek: true,
                            module: "weather",
                            header: 'Hengelo (OV)',
                            type: "current",
                            lat: "52.262600",
                            lon: "6.791080",
                            apiKey: "71b933c6f50387fd0ae3c5e2bc9345ba",
                            apiVersion: "2.5",
                            appendLocationNameToHeader: false,
                            weatherEndpoint: "/weather",
                            roundTemp: true
                            module: "weather",
                            header: "Voorspelling:",
                            type: "forecast",
                            lat: "52.262600",
                            lon: "6.791080",
                            apiVersion: "2.5",
                            weatherEndpoint: "/forecast",
                            roundTemp: true
                            module: 'MMM-Todoist',
                            position: 'bottom_right',       // This can be any of the regions. Best results in left or righ>
                            header: 'To do', // This is optional
                            config: { // See 'Configuration options' for more information.
                                    hideWhenEmpty: false,
                                    showProject: false,
                                    accessToken: '73e3463135d110d38785ab788e3198ac527bb28f',
                                    displayTasksWithinDays: 0,
                                    updateInterval: 600*60*1000, // Update every 10 hours
                                    fade: false,
                                    sortType: "dueDateAsc",
                                    // projects and/or labels is mandatory:
                                    projects: [ 2348560100 ],
                                    labels: [ "MagicMirror", "Important" ] // Tasks for any projects with these labels will>
                            position: "bottom_third", // This can be any of the regions. Best results in left or right regi>
                            header: "Agenda",
                                  // The config property is optional.
                                  // If no config is set, an example calendar is shown.
                                            symbol: "calendar-check-o",
                                            maximumNumberOfDays: "2",
                                            dateFormat: "D MMM",
                                            fetchinterval: 86400000,
                                            url: "https://calendar.google.com/calendar/ical/agendaonslombok8%40gmail.com/pr>
      //                      module: "MMM-WeatherBackground",
      //                      // don't assign position.
      //                      config: {
      //                              clientID: "Rom82DzfVYutBzBskWZxBkst96BoJyHOm3lH2kX7rfw",
      The error logs showing no error, never, not even when crashing. Syntax no errors.
        sdetweil @MrCoads
        @MrCoads only thing i can think of is one of the images is damaged.
          MrCoads @sdetweil
          @sdetweil Well, maybe… weird thing is, the first “word” it looked up was winter, getting all winter themed pictures. That crashed randomly at times. Now it went to Spring, still getting crashes. Different pics, same crashes :( …
            sdetweil @MrCoads
            @MrCoads id find some tool to run thru the images
            how old is the sd card?
              MrCoads @sdetweil
              @sdetweil Bought the SD Card 4 weeks ago… Rest of modules and everything runs fine…
              Maybe better to just use a Googel Drive or something to display images? What you think ?
                sdetweil @MrCoads
                @MrCoads i use a local file server, and link the mounted image source folder the module needs
                  MrCoads @sdetweil
                  @sdetweil I’ll probably do that then… Still haven’t found the solution tho :(
