    MM shifts to the right about 1cm after it loaded
    2 Posts 2 Posters 951 Views 2 Watching
    • JohanbaJ
      Johanba
      Hi Fellow MM enthusiast
      Since a few days about my MM shifts about 1cm to the right after loading the initial page, and for the life of me I cannot find the issue
      Any help will be appreciated
      Below I included my custom.css and main.css
      Not sure where else it could be
      custome.css
      "/* Custom CSS Sample
      • Change color and fonts here.
      • Beware that properties cannot be unitless, so for example write ‘–gap-body: 0px;’ instead of just ‘–gap-body: 0;’
      /* Uncomment and adjust accordingly if you want to import another font from the google-fonts-api: /
      @import url(‘https://fonts.googleapis.com/css2?family=Poppins:wght@100;300;400;700&display=swap’); */
      :root {
      –color-text: #999;
      –color-text-dimmed: #666;
      –color-text-bright: #fff;
      –color-background: black;
      –font-primary: “Roboto Condensed”;
      –font-secondary: “Roboto”;
      –font-size: 20px;
      –font-size-small: 0.75rem;
      –gap-body-top: 60px;
      –gap-body-right: 60px;
      –gap-body-bottom: 60px;
      –gap-body-left: 60px;
      –gap-modules: 30px;
      body {
      margin: 0;
      position: absolute;
      transform: rotate(-90deg);
      transform-origin: top left;
      width: 100vh;
      height: 100vw;
      object-fit: cover;
      top: 100vh;
      visibility: visible;
      main.css
      :root {
      –color-text: #999;
      –color-background: #000;
      –font-size: 20px;
      –font-size-xsmall: 0.75rem;
      –font-size-small: 1rem;
      –font-size-medium: 1.5rem;
      –font-size-large: 3.25rem;
      –font-size-xlarge: 3.75rem;
      –gap-modules: 30px;
      html {
      cursor: none;
      overflow: hidden;
      background: var(–color-background);
      user-select: none;
      font-size: var(–font-size);
      ::-webkit-scrollbar {
      display: none;
      body {
      margin: var(–gap-body-top) var(–gap-body-right) var(–gap-body-bottom) var(–gap-body-left);
      position: absolute;
      height: calc(100% - var(–gap-body-top) - var(–gap-body-bottom));
      width: calc(100% - var(–gap-body-right) - var(–gap-body-left));
      color: var(–color-text);
      font-family: var(–font-primary), sans-serif;
      font-weight: 400;
      line-height: 1.5;
      -webkit-font-smoothing: antialiased;
      • Default styles.
      .dimmed {
      color: var(–color-text-dimmed);
      .normal {
      .bright {
      color: var(–color-text-bright);
      .xsmall {
      font-size: var(–font-size-xsmall);
      line-height: 1.275;
      .small {
      font-size: var(–font-size-small);
      line-height: 1.25;
      .medium {
      font-size: var(–font-size-medium);
      line-height: 1.225;
      .large {
      font-size: var(–font-size-large);
      line-height: 1;
      .xlarge {
      font-size: var(–font-size-xlarge);
      line-height: 1;
      letter-spacing: -3px;
      .thin {
      font-family: var(–font-secondary), sans-serif;
      font-weight: 100;
      .light {
      font-weight: 300;
      .regular {
      font-weight: 400;
      .bold {
      font-weight: 700;
      .align-right {
      text-align: right;
      .align-left {
      text-align: left;
      header {
      text-transform: uppercase;
      font-family: var(–font-primary), Arial, Helvetica, sans-serif;
      font-weight: 400;
      border-bottom: 1px solid var(–color-text-dimmed);
      line-height: 15px;
      padding-bottom: 5px;
      margin-bottom: 10px;
      sup {
      font-size: 50%;
      line-height: 50%;
      • Module styles.
      .module {
      margin-bottom: var(–gap-modules);
      .module.hidden {
      pointer-events: none;
      .module:not(.hidden) {
      pointer-events: auto;
      .region.bottom .module {
      margin-top: var(–gap-modules);
      margin-bottom: 0;
      .no-wrap {
      white-space: nowrap;
      overflow: hidden;
      text-overflow: ellipsis;
      .pre-line {
      white-space: pre-line;
      • Region Definitions.
      .region {
      position: absolute;
      .region.fullscreen {
      position: absolute;
      inset: calc(-1 * var(–gap-body-top)) calc(-1 * var(–gap-body-right)) calc(-1 * var(–gap-body-bottom)) calc(-1 * var(–gap-body-left));
      .region.right {
      right: 0;
      text-align: right;
      .region.top {
      top: 0;
      .region.top.center,
      .region.bottom.center {
      left: 50%;
      transform: translateX(-50%);
      .region.top.right,
      .region.top.left,
      .region.top.center {
      top: 100%;
      .region.bottom {
      bottom: 0;
      .region.bottom.right,
      .region.bottom.center,
      .region.bottom.left {
      bottom: 100%;
      .region.bar {
      width: 100%;
      text-align: center;
      .region.third,
      .region.middle.center {
      width: 100%;
      text-align: center;
      transform: translateY(-50%);
      .region.upper.third {
      top: 33%;
      top: 50%;
      .region.lower.third {
      top: 66%;
      .region.left {
      text-align: left;
      .region table {
      width: 100%;
      border-spacing: 0;
      border-collapse: separate;
        sdetweil @Johanba
        @Johanba said in MM shifts to the right about 1cm after it loaded:
        custome.css
        that is a typo, yes??
        custom.css
        also, see the developers window elements tab
        see the second link in my signature below
        this may help you identify where the left margin padding is coming from
