    REMOTE CONTROL UPDATE
    19 Posts 2 Posters 3.9k Views 2 Watching
    • P Offline
      pat59
      Hello, wanting to update the remote control module with this remote control my mirror does not restart what should I do?
      S 1 Reply Last reply Reply Quote -1
        sdetweil @pat59
        @pat59 hm. worrying. lets try this
        from a terminal window
        cd ~/MagicMirror/modules
        mv  MMM-Remote-Control save-remote
        git clone https://github.com/Jopyth/MMM-Remote-Control
        cd MMM-Remote-Control
        npm install
        pm2 restart mm
        stop if you get an error
        the error implies a failing sd card, backup now
          sdetweil @pat59
          @pat59 show the messages from pm2
          pm2 logs --lines=100
            @pat59 what did you update? module or MagicMirror
            • P Offline
              pat59
              I updated with cd ~/MagicMirror
              how to make you see the messages of pm2
                sdetweil @pat59
                @pat59 MORE than likely you upgraded which didn’t handle the nodejs requirement
                can you get to a commandline on the mirror?
                ssh, vnc?
                • P Offline
                  pat59
                  pi@raspberrypi:~/MagicMirror $ pm2 logs mm
                  [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                  /home/pi/.pm2/logs/mm-error.log last 15 lines:
                  0|mm | at resolveExports (node:internal/modules/cjs/loader:550:15)
                  0|mm | at Module._findPath (node:internal/modules/cjs/loader:628:31)
                  0|mm | at Module._resolveFilename (node:internal/modules/cjs/loader:1041:27)
                  0|mm | at s._resolveFilename (node:electron/js2c/browser_init:2:115476)
                  0|mm | at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                  0|mm | at Module._load (node:internal/modules/cjs/loader:908:27)
                  0|mm | at c._load (node:electron/js2c/node_init:2:13672)
                  0|mm | at Module.require (node:internal/modules/cjs/loader:1122:19)
                  0|mm | at require (node:internal/modules/helpers:130:18)
                  0|mm | at Object. (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:18:19)
                  0|mm | at Module._compile (node:internal/modules/cjs/loader:1256:14)
                  0|mm | at Module._extensions…js (node:internal/modules/cjs/loader:1311:10)
                  0|mm | at Module.load (node:internal/modules/cjs/loader:1098:32)
                  0|mm | (Use electron --trace-warnings ... to show where the warning was created)
                  0|mm | [2025-03-09 20:02:43.107] [ERROR] (node:1422) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
                  /home/pi/.pm2/logs/mm-out.log last 15 lines:
                  0|mm | [2025-03-09 19:58:14.225] [LOG] config template file not exists, no envsubst
                  0|mm | [2025-03-09 19:58:14.239] [LOG] Loading module helpers …
                  0|mm |
                  0|mm | > magicmirror@2.27.0 start
                  0|mm | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                  0|mm |
                  0|mm | [2025-03-09 20:02:41.778] [LOG] Starting MagicMirror: v2.27.0
                  0|mm | [2025-03-09 20:02:41.852] [LOG] Loading config …
                  0|mm | [2025-03-09 20:02:41.858] [LOG] config template file not exists, no envsubst
                  0|mm | [2025-03-09 20:02:41.870] [LOG] Loading module helpers …
                  0|mm | [2025-03-09 20:02:53.609] [INFO] System information:
                  0|mm | ### SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model B Plus Rev 1.3; raspberry: [object Object]; virtual: false
                  0|mm | ### OS: platform: linux; distro: Raspbian GNU/Linux; release: 10; arch: arm; kernel: 5.10.103-v7+
                  0|mm | ### VERSIONS: electron: 29.1.6; used node: 20.9.0; installed node: 18.18.0; npm: 9.8.1; pm2: 5.3.1
                  0|mm | ### OTHER: timeZone: Europe/Paris; ELECTRON_ENABLE_GPU: undefined
                  • P Offline
                    pat59
                    pi@raspberrypi:~/MagicMirror $ ssh
                    usage: ssh [-46AaCfGgKkMNnqsTtVvXxYy] [-B bind_interface]
                    [-b bind_address] [-c cipher_spec] [-D [bind_address:]port]
                    [-E log_file] [-e escape_char] [-F configfile] [-I pkcs11]
                    [-i identity_file] [-J [user@]host[:port]] [-L address]
                    [-l login_name] [-m mac_spec] [-O ctl_cmd] [-o option] [-p port]
                    [-Q query_option] [-R address] [-S ctl_path] [-W host:port]
                    [-w local_tun[:remote_tun]] destination [command]
                      sdetweil @pat59
                      @pat59 pm2 need more lines
                      ssh FROM pc TO pi
                      • P Offline
                        pat59
                        Hello
                        sorry, being a novice, I don’t understand what to do
                          sdetweil @pat59
                          @pat59 pm2 logs MagicMirror lines=100
                          • P Offline
                            pat59
                            it doesn’t give me more lines.
                            pi@raspberrypi:~/MagicMirror $ pm2 logs MagicMirror
                            [TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
                            /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                            1|MagicMir | at resolveExports (node:internal/modules/cjs/loader:550:15)
                            1|MagicMir | at Module._findPath (node:internal/modules/cjs/loader:628:31)
                            1|MagicMir | at Module._resolveFilename (node:internal/modules/cjs/loader:1041:27)
                            1|MagicMir | at s._resolveFilename (node:electron/js2c/browser_init:2:115476)
                            1|MagicMir | at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                            1|MagicMir | at Module._load (node:internal/modules/cjs/loader:908:27)
                            1|MagicMir | at c._load (node:electron/js2c/node_init:2:13672)
                            1|MagicMir | at Module.require (node:internal/modules/cjs/loader:1122:19)
                            1|MagicMir | at require (node:internal/modules/helpers:130:18)
                            1|MagicMir | at Object. (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:18:19)
                            1|MagicMir | at Module._compile (node:internal/modules/cjs/loader:1256:14)
                            1|MagicMir | at Module._extensions…js (node:internal/modules/cjs/loader:1311:10)
                            1|MagicMir | at Module.load (node:internal/modules/cjs/loader:1098:32)
                            1|MagicMir | (Use electron --trace-warnings ... to show where the warning was created)
                            1|MagicMir | [2025-03-10 17:29:32.437] [ERROR] (node:1154) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
                            /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                            1|MagicMir | ### VERSIONS: electron: 29.1.6; used node: 20.9.0; installed node: 18.18.0; npm: 9.8.1; pm2: 5.3.1
                            1|MagicMir | ### OTHER: timeZone: Europe/Paris; ELECTRON_ENABLE_GPU: undefined
                            1|MagicMir |
                            1|MagicMir | > magicmirror@2.27.0 start
                            1|MagicMir | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                            1|MagicMir |
                            1|MagicMir | [2025-03-10 17:29:30.987] [LOG] Starting MagicMirror: v2.27.0
                            1|MagicMir | [2025-03-10 17:29:31.052] [LOG] Loading config …
                            1|MagicMir | [2025-03-10 17:29:31.064] [LOG] config template file not exists, no envsubst
                            1|MagicMir | [2025-03-10 17:29:31.078] [LOG] Loading module helpers …
                            1|MagicMir | [2025-03-10 17:29:44.233] [INFO] System information:
                            1|MagicMir | ### SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model B Plus Rev 1.3; raspberry: [object Object]; virtual: false
                            1|MagicMir | ### OS: platform: linux; distro: Raspbian GNU/Linux; release: 10; arch: arm; kernel: 5.10.103-v7+
                              sdetweil @pat59
                              @pat59 correct, you didn’t ask for more lines
                              pm2 logs mm --lines=100
                              • P Offline
                                pat59
                                this is what he gives me.
                                pi@raspberrypi:~ $ cd ~/MagicMirror
                                pi@raspberrypi:~/MagicMirror $ pm2 logs mm --lines=100
                                [TAILING] Tailing last 100 lines for [mm] process (change the value with --lines option)
                                /home/pi/.pm2/logs/mm-error.log last 100 lines:
                                0|mm | [2025-03-09 19:48:01.357] [ERROR] (node:2136) UnhandledPromiseRejectionWarning: SyntaxError: Error parsing /home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/simple-git/package.json: Unexpected end of JSON input
                                0|mm | at parse ()
                                0|mm | at Object.read (node:internal/modules/package_json_reader:75:16)
                                0|mm | at readPackage (node:internal/modules/cjs/loader:369:28)
                                0|mm | [2025-03-09 19:48:01.361] [ERROR] (node:2136) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
                                0|mm | Gdk-Message: 19:48:14.328: electron: Fatal IO error 11 (Ressource temporairement non disponible) on X server :0.
                                0|mm |
                                0|mm | [2025-03-09 19:58:15.652] [ERROR] (node:1753) UnhandledPromiseRejectionWarning: SyntaxError: Error parsing /home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/simple-git/package.json: Unexpected end of JSON input
                                0|mm | at parse ()
                                0|mm | [2025-03-09 19:58:15.659] [ERROR] (node:1753) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
                                0|mm | Gdk-Message: 19:58:23.609: electron: Fatal IO error 0 (Succès) on X server :0.
                                0|mm |
                                0|mm | [2025-03-09 20:02:43.104] [ERROR] (node:1422) UnhandledPromiseRejectionWarning: SyntaxError: Error parsing /home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/simple-git/package.json: Unexpected end of JSON input
                                0|mm | at parse ()
                                0|mm | Gdk-Message: 20:54:50.269: electron: Fatal IO error 11 (Ressource temporairement non disponible) on X server :0.
                                0|mm |
                                0|mm | [2025-03-10 17:50:25.427] [ERROR] (node:2106) UnhandledPromiseRejectionWarning: SyntaxError: Error parsing /home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/simple-git/package.json: Unexpected end of JSON input
                                0|mm | at parse ()
                                0|mm | [2025-03-10 17:50:25.430] [ERROR] (node:2106) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
                                /home/pi/.pm2/logs/mm-out.log last 100 lines:
                                0|mm |
                                0|mm |
                                0|mm | [2025-03-09 19:47:59.893] [LOG] Starting MagicMirror: v2.27.0
                                0|mm | [2025-03-09 19:47:59.962] [LOG] Loading config …
                                0|mm | [2025-03-09 19:47:59.971] [LOG] config template file not exists, no envsubst
                                0|mm | [2025-03-09 19:47:59.980] [LOG] Loading module helpers …
                                0|mm |
                                0|mm |
                                0|mm | [2025-03-09 19:58:14.143] [LOG] Starting MagicMirror: v2.27.0
                                0|mm | [2025-03-09 19:58:14.212] [LOG] Loading config …
                                0|mm |
                                0|mm |
                                0|mm |
                                0|mm |
                                0|mm | [2025-03-10 17:50:17.717] [LOG] Starting MagicMirror: v2.27.0
                                0|mm | [2025-03-10 17:50:17.811] [LOG] Loading config …
                                0|mm | [2025-03-10 17:50:17.824] [LOG] config template file not exists, no envsubst
                                0|mm | [2025-03-10 17:50:17.843] [LOG] Loading module helpers …
                                0|mm | [2025-03-10 17:50:47.882] [INFO] System information:
                                  sdetweil @pat59
                                  npm install
                                  pm2 restart mm
                                  • P Offline
                                    pat59
                                    pi@raspberrypi:~ $ cd ~/MagicMirror/modules
                                    pi@raspberrypi:~/MagicMirror/modules $ mv MMM-Remote-control save-remote
                                    mv: impossible d’évaluer ‘MMM-Remote-control’: Aucun fichier ou dossier de ce type
                                    pi@raspberrypi:~/MagicMirror/modules $ git clone https://github/Jopyth/MMM-Remote-Control
                                    fatal: le chemin de destination ‘MMM-Remote-Control’ existe déjà et n’est pas un répertoire vide.
                                    pi@raspberrypi:~/MagicMirror/modules $ cd MMM-Remote-control
                                    bash: cd: MMM-Remote-control: Aucun fichier ou dossier de ce type
                                    pi@raspberrypi:~/MagicMirror/modules $ cd MMM-Remote-Control
                                    pi@raspberrypi:~/MagicMirror/modules/MMM-Remote-Control $ npm install
                                    npm ERR! code ENOTEMPTY
                                    npm ERR! syscall rename
                                    npm ERR! path /home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/cspell
                                    npm ERR! dest /home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/.cspell-Sdwzuw3y
                                    npm ERR! errno -39
                                    npm ERR! ENOTEMPTY: directory not empty, rename ‘/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/cspell’ -> ‘/home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/.cspell-Sdwzuw3y’
                                    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2025-03-10T18_40_59_208Z-debug-0.log
                                      sdetweil @pat59
                                      @pat59 MagicMirror is case sensitive
                                      control is not the same as Control
                                      • P Offline
                                        pat59
                                        so there is nothing more to do l have to restart my Mirror cordially
                                        • P Offline
                                          pat59
                                          I redid the entire process, I must have made a typing error, everything went normally, the mirror function, I don’t know how to thank you, I’m so happy
                                            sdetweil @pat59
                                            @pat59 awesome
