    PIR sensor repositories are outdated
    4 Posts 2 Posters 973 Views 2 Watching
      jaimegarzont
      Hey guys, im currently trying to implement a PIR sensor in my magic mirror, But every module i attempt to use gives me an error, Right now im dealing with the following error after cloning this repository https://github.com/vpilo/MMM-Pir
      13:25:04.159] [ERROR] [MMM-Pir] [LIB] [PIR] [GPIOD] Error: The module ‘/home/jaimegarzont/MagicMirror/modules/MMM-Pir/node_modules/node-libgpiod/build/Release/node-libgpiod.node’
      was compiled against a different Node.js version using
      NODE_MODULE_VERSION 128. This version of Node.js requires
      NODE_MODULE_VERSION 115. Please try re-compiling or re-installing
      the module (for instance, using npm rebuild or npm install).
      is there any Module i can clone that still works? or is there another way i can connect the sensor so the MM turns off when no one is in front of it
        sdetweil @jaimegarzont
        @jaimegarzont
        maybe this one
        https://gitlab.com/khassel/MMM-Universal-Pir
        the 3rd party module list is linked from the top
        menu here
        J 2 Replies Last reply Reply Quote 0
          jaimegarzont @sdetweil
          @sdetweil thanks, ill try it out :)
            @sdetweil Ita worked! tank you sooooo much
