    Combining MMM-GroveGestures and MMM-Page-Selector
    7 Posts 2 Posters 1.0k Views 2 Watching
    • C Offline
      ChanceTime
      Hi there! I’m on my third update of my Magic Mirror after the previous OS revision of Raspbian busted my RPi (I wasn’t able to generate a taskbar until Bookworm came out??) and am trying to restore some of the functionality I had in rev 1 of my build, where I could use MMM-GroveGestures to swap between pages of modules. I tested and the sensor works, and I am able to get recognition of the gesture movement when I move my hand in front of the sensor in the MM app, but I think there must be an issue in the notification being sent to MMM-Page-Selector and I am stumped. I tried using this.SendNotification and continually got errors as well (I’ll leave the commented versions in in case that was my issue).
      A lightly redacted version of my config file is below:
      /* Config Sample
       * see https://docs.magicmirror.builders/configuration/introduction.html
       * and https://docs.magicmirror.builders/modules/configuration.html
       * You can use environment variables using a `config.js.template` file instead of `config.js`
       * which will be converted to `config.js` while starting. For more information
       * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
      let config = {
      port: 8080,
      basePath: "/", // The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
      ipWhitelist: [redacted], // Set [] to allow all IP addresses
      useHttps: false, // Support HTTPS or not, default "false" will use HTTP
      httpsPrivateKey: "", // HTTPS private key path, only require when useHttps is true
      httpsCertificate: "", // HTTPS Certificate path, only require when useHttps is true
      language: "en",
      locale: "en-CA",   // this variable is provided as a consistent location
        // it is currently only used by 3rd party modules. no MagicMirror code uses this value
        // as we have no usage, we  have no constraints on what this field holds
        // see https://en.wikipedia.org/wiki/Locale_(computer_software) for the possibilities
      timeFormat: 12,
      units: "metric",
      module: "MMM-Page-Selector",
      position: "top_center",
      defaultPage: "mainPage",
      displayTitle: false,
      selectPageNotif: ["PAGE_SELECT"],
      incrementPageNotif: ["PAGE_UP"],
      decrementPageNotif: ["PAGE_DOWN"],
      persistentPages: true,
      module: "MMM-GroveGestures",
      //position: "top_right",
      pages: {"all": "top_right"},
      autoStart: true,
      verbose: false,
      recognitionTimeout: 1000,
      idleTimer: 0,
      defaultNotification: "GESTURE",
      pythonPath: "/usr/bin/python",
      defaultCommandSet: "default",
      commandSet: {
      "default": {
      "FORWARD": {
      notificationExec: {
      notification: "PAGE_SELECT",
      payload: "mainPage",
      //this.sendNotification: ("PAGE_SELECT", "mainPage");
      "BACKWARD": {
      notificationExec: {
      payload: "work",
      //this.sendNotification("PAGE_SELECT", "work"),
      "UP": {
      module: "alert",
      // pages: {"all": "top_bar"},
      module: "updatenotification",
      //position: "top_bar"
      module: "clock",
      //position: "top_left"
      pages: {"mainPage": "top_left"},
      header: "Calendar",
      //position: "top_left",
      symbol: "calendar-check",
      url: "redacted.ics",
      header: "Upcoming Birthdays",
      url: "redacted.ics"
      module: 'MMM-Block',
      //position: 'top_right',
      pages: {"mainPage": "top_right"},
      height: 132,
      module: 'MMM-EnvCanada',
      header: "Environment Canada",
      config:{
      siteCode: "redacted",
      provCode: "ON",
      updateInterval: 10 * 60 * 1000,
      language: "e",
      textForecasts: 2,
      showAlerts: true,
      showForecastDays: 5,
      module: 'MMM-Todoist',
      //position: 'bottom_bar',
      pages: {"mainPage": "bottom_bar"},
      header: 'Todoist',
      hideWhenEmpty: false,
      accessToken: 'redacted',
      maximumEntries: 10,
      fade: false,
      //projects: [],
      labels: ['MagicMirror'],
      // Work!
      module: "MMM-SpaceLaunch",
      pages: {"work": "top_right"},
      showMission: true,
      showLaunchDate: true,
      showRocket: true,
      showLaunchSite: true,
      showLocation: false,
      showPayload: true,
      showOrbit: true,
      showDetails: false,
      Thanks in advance!
      • C Offline
        ChanceTime @sdetweil
        @sdetweil nevermind - I fixed it thanks to your suggestion to use the second module! Found where GESTURE_DETECTED was coming from in MMM-GroveGestures.js and edited my notifications in there. I really appreciate your support!
          sdetweil @ChanceTime
          @ChanceTime said in Combining MMM-GroveGestures and MMM-Page-Selector:
          MagicMirror is case sensitive
          this.sendNotfication, is not the same as this.SendNotification
          I do not know if ‘this’ is set at the time of use in config.js
          but you do not need any code, there is configuration for
          what notification to send and what data(payload) goes with it , and you are using those
          "BACKWARD": {
          notificationExec: {
          payload: "work",
          I would install MMM-ViewNotifications to see if the notifications are being sent
          C 3 Replies Last reply Reply Quote 0
          • C Offline
            @sdetweil ah!! Thanks so much for this - I’ll give it a shot when I get home this evening and report back. :)
            • C Offline
              @sdetweil so I tested with MMM-ViewNotifications! I am seeing MMM-GroveGestures GESTURE_DETECTED get registered, but nothing from inside of the movement (FORWARD, BACKWARD) from the MMM-GroveGestures section despite the correct movements being shown on the screen. Any ideas?
              • C Offline
                  @ChanceTime awesome!!!
                    @ChanceTime you edited in config.js, right?
                    never edit the module source
