    OpenWeatherForcast - Request failed with status code 401
    3 Posts 2 Posters 773 Views 2 Watching
    • butchkemperB Offline
      butchkemper
      I had a MagicMirror that was running on Bullseye and I decided to upgrade to Bookworm. Note to self “Leave running systems alone”.
      Bookworm runs, MM starts up, and the modules for Calendar and MMM-Fuel are working properly. However, the MMM-OpenWeatherForecast module does not display any information and this error message is in the MagicMirror-out.log:
      ** ERROR ** Error: Request failed with status code 401
      There are no other error messages from OpenWeatherForecast.
      Any hints would be appreciated.
      Butch Kemper
      Resistance is not Futile!
      It is voltage divided by current.
        butchkemper
        Problem solved. There are multiple MMM-OpenWeatherForecast repositories. The one I cloned for the new system was not the clone I was previously using. I changed to the module from Tom-Hirschberger/MMM-OpenWeatherForecast and everything began working as expected.
        I apologize for my error.
        Update: To prevent future issues, I have add a comment in config/config.js file on each module statement to remind me of the module repository location. The comment appears as: // github.com/Tom-Hirschberger/MMM-OpenWeatherForecast.
        Butch Kemper
          sdetweil @butchkemper
          @butchkemper yes, see
          https://forum.magicmirror.builders/topic/19323/version-2-30-0-weather-module-stuck-loading-worked-fine-before-upgrade
            butchkemper
            Butch Kemper
