    Storing info locally
    4 Posts 3 Posters 634 Views 3 Watching
    • L
      LittleB
      I am writing a module using Strava api, to show my last run, best times e.t.c. Got some some code working but was wondering how you can store data (for a module) in a local file.
      Strava uses OAuth 2.0 and has tokens that time out so when your token times out you call a url (with old token) and it gives you a new one. When I get the new token I want to store this new token somewhere on the raspberry pi so I can use this new token when I next make a request.
      I have made a few modules myself and all work nicely but could not find an example on how to store a value somewhere and be able to override it?
      • karsten13K
        karsten13 @sdetweil
        see https://github.com/ianperrin/MMM-Strava
        L 1 Reply Last reply Reply Quote 1
          sdetweil @LittleB
          @LittleB use the node_helper.js
          it can execute the code to generate the token and read/write
          files.
          look at the spotify, googlephotos… modules for examples
          • karsten13K
            karsten13 @sdetweil
            • L LittleB has marked this topic as solved on
            • L
              LittleB @karsten13
              @karsten13 said in Storing info locally:
              Many thanks will take a look!
