    Black screen on the radxa ROCK 2F, using docker
    4 Posts 3 Posters 2.0k Views 3 Watching
      ajoreis
      Hello,
      I have a problem with my Mirror Docker.
      My hardware is not a Raspberry PI but a radxa ROCK 2F with a 128 GB SC card.
      I have Docker and Portainer installed, and of course also the Mirror Docker software.
      When I start the Docker container, I get a black screen and unfortunately, no content from the Mirror software is displayed.
      I get the following error when starting the labwc container:
      2025-03-31T16:06:59.604820724Z chown: cannot access ‘/run/user/1001/gvfs’: Permission denied
      986
      2025-03-31T16:06:59.653329660Z 00:00:00.000 [INFO] [seatd/seatd.c:167] Removing leftover socket at /run/seatd.sock
      987
      2025-03-31T16:06:59.653921766Z 00:00:00.000 [INFO] [seatd/seat.c:48] Created VT-bound seat seat0
      988
      2025-03-31T16:06:59.654542456Z 00:00:00.001 [INFO] [seatd/seatd.c:194] seatd started
      989
      2025-03-31T16:06:59.785464662Z 00:00:00.132 [INFO] [seatd/server.c:145] New client connected (pid: 16, uid: 1000, gid: 1000)
      990
      2025-03-31T16:06:59.785672337Z 00:00:00.132 [INFO] [seatd/seat.c:239] Added client 2 to seat0
      991
      2025-03-31T16:06:59.786233817Z 00:00:00.132 [INFO] [seatd/seat.c:563] Opened client 2 on seat0
      992
      2025-03-31T16:06:59.797688879Z 00:00:00.144 [ERROR] [seatd/seat.c:387] Could not make device fd drm master: Device or resource busy
      993
      2025-03-31T16:07:00.061181559Z libEGL warning: egl: failed to create dri2 screen
      994
      2025-03-31T16:07:00.061300855Z 00:00:00.278 [ERROR] [EGL] command: eglInitialize, error: EGL_NOT_INITIALIZED (0x3001), message: “DRI2: failed to create screen”
      995
      2025-03-31T16:07:00.085743162Z libEGL warning: egl: failed to create dri2 screen
      996
      2025-03-31T16:07:00.085860708Z 00:00:00.303 [ERROR] [EGL] command: eglInitialize, error: EGL_NOT_INITIALIZED (0x3001), message: “DRI2: failed to create screen”
      997
      2025-03-31T16:07:00.110807617Z 00:00:00.457 [INFO] [seatd/client.c:496] Client disconnected
      998
      2025-03-31T16:07:00.110951123Z 00:00:00.457 [ERROR] [seatd/seat.c:442] Could not revoke drm master on device fd: Invalid argument
      999
      2025-03-31T16:07:00.111026375Z 00:00:00.457 [INFO] [seatd/seat.c:158] No clients on seat0 to activate
      1000
      2025-03-31T16:07:00.111250092Z /entrypoint.sh: line 21: 16 Segmentation fault labwc
      The MM container keeps restarting because it doesn’t have a display:
      2025-03-31T16:09:56.570445772Z [58:0331/180956.569442:ERROR:ozone_platform_x11.cc(245)] Missing X server or $DISPLAY
      988
      2025-03-31T16:09:56.571702893Z [58:0331/180956.570634:ERROR:env.cc(258)] The platform failed to initialize. Exiting.
      989
      2025-03-31T16:09:57.087712870Z /opt/magic_mirror/node_modules/electron/dist/electron exited with signal SIGSEGV
      What do I have to do to get the labwc container to start or initialize the display?
      Thank you very much for any information.
      Best regards,
      Olaf
      karsten13K 1 Reply Last reply Reply Quote 1
      • karsten13K Offline
        karsten13 @ajoreis
        @ajoreis said in Black screen on the radxa ROCK 2F, using docker:
        that tells you that labwc crashes, further investigation without having the used hardware is impossible.
        S A 2 Replies Last reply Reply Quote 1
          sdetweil @karsten13
          @karsten13 this seems telling
            ajoreis @karsten13
            @karsten13 Hello,
            I’ve given up. I’ve tried the following.
            I created a new image, currently only available for the Rock-F2.
            A Debian Bullseye Desktop LXDM display manager (Debian Xfce) without an X server.
            I’m currently using an RPi 3 again, and I’ve managed to get everything working.
            Thanks very much for your support.
            Olaf
