    Electron.js error
    3 Posts 2 Posters 610 Views 2 Watching
      anonymous321
      I’ve been getting a lot of issue trying to get magic mirror to start. I’m starting to get a little frustrated as I decided to wait a few months to finish this project due to issues with the calendar update that I could not resolve. I tried using the following script to install MM sdetweil /MagicMirror_scripts. Im getting the following error on a raspberry pi 3 model. I have the install.log file but im not sure how to upload it.
      > magicmirror@2.31.0 start
      > > npm run start:x11
      > > magicmirror@2.31.0 start:x11
      > > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      > [2025-04-11 23:09:32.767] [ERROR] App threw an error during load
      > [2025-04-11 23:09:32.777] [ERROR] TypeError: Log.log is not a function
      >     at Object.<anonymous> (/home/pi/MagicMirror-old/js/app.js:22:5)
      >     at Module._compile (node:internal/modules/cjs/loader:1569:14)
      >     at Module._extensions..js (node:internal/modules/cjs/loader:1722:10)
      >     at Module.load (node:internal/modules/cjs/loader:1296:32)
      >     at Module._load (node:internal/modules/cjs/loader:1115:12)
      >     at c._load (node:electron/js2c/node_init:2:18008)
      >     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
      >     at wrapModuleLoad (node:internal/modules/cjs/loader:227:24)
      >     at Module.require (node:internal/modules/cjs/loader:1318:12)
      >     at require (node:internal/modules/helpers:136:16)
      >     at Object.<anonymous> (/home/pi/MagicMirror-old/js/electron.js:4:14)
      > A JavaScript error occurred in the main process
      > Uncaught Exception:
      > [2025-04-11 23:09:32.784] [ERROR] (node:35524) [DEP0025] DeprecationWarning: sys is deprecated.
      > (Use `electron --trace-deprecation ...` to show where the warning was created)
      > Uncaught Exception:
        sdetweil @anonymous321
        @anonymous321 install.log is just a text file, you copy/paste same as you did for the error list
        is this a new install or later?
          @anonymous321 can you do this
          cd ~/MagicMirror/vendor
          npm install
          cd ../fonts
          npm install
          and restart MagicMirror
