Nextcloud calendar error
@theaddies this sounds like v 2.30, w the clipping problem
fixed in 2.31
@sdetweil I switched to the branch described in the other post and nothing changed. I switched back to main and I give up. Thanks very much for the help. I really appreciate it.
@theaddies the 2.30 fix branch isn’t there unless you manually install it
@sdetweil I did this. Nothing changed.
cd ~/MagicMirror git fetch origin pull/3679/head:_fix_clipping git switch _fix_clipping npm run install-mm # if you get an error error, rm package-lock.json # and repeat the git switch restart MM -
@theaddies said in Nextcloud calendar error:
maximumEntries: 5,if you try 100 instead of 5 does it make a difference?
