    Nextcloud calendar error
    15 Posts 2 Posters 6.6k Views 2 Watching
      sdetweil @theaddies
      @theaddies said in Nextcloud calendar error:
      04-12 04:24:55.238] [INFO] Calendar-Fetcher: Broadcasting 8 events from https://xxxxxxxxxxx.com/remote.php/dav/calendars/admin/personal?export
      looks like it recovered for one
      • T
        theaddies
        I made the changes here disabling IPV6 and they seem to work now.
        disable IPV6
        However I have one calendar that just says loading on the mirror and it doesn’t change. The log thinks it has pulled the calendar but it never displays.
        0|MagicMirror  | [2025-04-12 08:44:45.983] [INFO]  Calendar-Fetcher: Broadcasting 9 events from https://xxxxxxx.com/remote.php/dav/calendars/admin/work?export.
        S T 2 Replies Last reply
          sdetweil @theaddies
          @theaddies are those old events? we don’t display past events…
          • T
            theaddies @theaddies
            @sdetweil Thanks for the reply. Nope, not old events. 2 of the calendars have loaded. The work calendar just says “Loading …” on the Pi.
              sdetweil @theaddies
              @theaddies but the log said failed
              comment out the other cal definitions, so only that one is active
              /* …*/ is comment block
              • T
                theaddies
                I removed all calendars but the work one. It just says “Loading …”.
                0|MagicMir | [2025-04-12 08:59:19.015] [LOG]   No helper found for module: calendar_monthly.
                0|MagicMir | [2025-04-12 08:59:19.316] [LOG]   Module helper loaded: calendar
                0|MagicMir | [2025-04-12 08:59:22.922] [LOG]   Connecting socket for: calendar
                0|MagicMir | [2025-04-12 08:59:22.925] [LOG]   Starting node helper for: calendar
                0|MagicMirror  | [2025-04-12 08:59:32.795] [LOG]   Create new calendarfetcher for url: https://x.com/remote.php/dav/calendars/admin/work?export - Interval: 3600000
                0|MagicMirror  | [2025-04-12 08:59:34.361] [INFO]  Checking git for module: calendar_monthly
                0|MagicMirror  | [2025-04-12 09:00:47.009] [INFO]  Calendar-Fetcher: Broadcasting 486 events from https://x.com/remote.php/dav/calendars/admin/work?export.
                The config file is below.
                                        header: "Work",
                                        position: "top_left",   // This can be any of the regions. Best results in left or right regions.
                                                //colored: true,
                                                //coloredSymbolOnly: true,
                                                //limitDays1
                                                        url: 'https://x.com/remote.php/dav/calendars/admin/work?expor>
                                                        //symbol: 'briefcase',
                                                        auth: {
        user: 'admin',
        pass: 'xxxxxx',
        method: 'basic'
                                                        maximumEntries: 5,
                //                                        maximumNumberOfDays: 4,
                S 2 Replies Last reply
                  sdetweil @theaddies
                  @theaddies ok, can you open the developers window
                  ctrl-shift-i, select the console tab, and entry cal in the filter field
                  see if there is any error?
                  maximumEntries:5 could be limiting too
                  • T
                    theaddies @sdetweil
                    @sdetweil I am only using ssh. I will plug a keyboard into it.
                    • T
                      theaddies @sdetweil
                      @sdetweil OK, so in the console I do see the message below over and over and over. That is the only thing that appears odd to me.
                      slicing events total maxcount = 10   Calendar_js:744
                      sorting events count =0 Calendar_js: 704
                        sdetweil @theaddies
                        @theaddies this sounds like v 2.30, w the clipping problem
                        https://forum.magicmirror.builders/topic/19282/version-2.30.0-calendar-fix-for-clipping-broadcast-events
                        fixed in 2.31
                        T 1 Reply Last reply
                        • T
                          theaddies @sdetweil
                          @sdetweil I switched to the branch described in the other post and nothing changed. I switched back to main and I give up. Thanks very much for the help. I really appreciate it.
                            sdetweil @theaddies
                            @theaddies the 2.30 fix branch isn’t there unless you manually install it
                            • T
                              theaddies @sdetweil
                              @sdetweil I did this. Nothing changed.
                              git fetch origin pull/3679/head:_fix_clipping
                              git switch _fix_clipping
                              npm run install-mm
                              # if you get an error error, rm package-lock.json
                              # and repeat the git switch
                              restart MM
                                sdetweil @theaddies
        maximumEntries: 5,
                                if you try 100 instead of 5 does it make a difference?
