    Nextcloud calendar error
    15 Posts 2 Posters 6.6k Views 2 Watching
    • T
      theaddies
      I would appreciate any help that could be provided to resolve the error below. When I paste the url into a browser it asks for username and password and downloads a .ics file. seems to be working.
      pi@mirror:~ $ pm2 logs --lines=150 | grep calendar
      (node:1722) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
      (Use `node --trace-deprecation ...` to show where the warning was created)
      0|MagicMir | [2025-04-07 11:16:40.134] [ERROR] Calendar Error. Could not fetch calendar:  https://xxxxxxxx.com/remote.php/dav/calendars/admin/personal?export TypeError: fetch failed
      0|MagicMir | [2025-04-09 14:20:23.014] [ERROR] Calendar Error. Could not fetch calendar:  https://xxxxxxxxxxx.com/remote.php/dav/calendars/admin/personal?export TypeError: fetch failed
      0|MagicMir | [2025-04-11 19:24:15.796] [ERROR] Calendar Error. Could not fetch calendar:  https://xxxxxxxxxxx.com/remote.php/dav/calendars/admin/personal?export TypeError: fetch failed
      0|MagicMir | [2025-04-12 07:48:48.631] [ERROR] Calendar Error. Could not fetch calendar:  https://xxxxxxxxxxx.com/remote.php/dav/calendars/admin/work?export TypeError: terminated
      0|MagicMir | [2025-04-12 07:48:50.089] [ERROR] Calendar Error. Could not fetch calendar:  https://xxxxxxxxxxx.com/remote.php/dav/calendars/admin/work?export TypeError: terminated
      0|MagicMir | [2025-04-12 04:24:55.238] [INFO]  Calendar-Fetcher: Broadcasting 8 events from https://xxxxxxxxxxx.com/remote.php/dav/calendars/admin/personal?export.
        sdetweil @theaddies
        @theaddies said in Nextcloud calendar error:
        looks like it recovered for one
        • T
          theaddies
          I made the changes here disabling IPV6 and they seem to work now.
          disable IPV6
          However I have one calendar that just says loading on the mirror and it doesn’t change. The log thinks it has pulled the calendar but it never displays.
          0|MagicMirror  | [2025-04-12 08:44:45.983] [INFO]  Calendar-Fetcher: Broadcasting 9 events from https://xxxxxxx.com/remote.php/dav/calendars/admin/work?export.
          S T 2 Replies Last reply Reply Quote 0
            sdetweil @theaddies
            @theaddies are those old events? we don’t display past events…
            • T
              theaddies @theaddies
              @sdetweil Thanks for the reply. Nope, not old events. 2 of the calendars have loaded. The work calendar just says “Loading …” on the Pi.
                sdetweil @theaddies
                @theaddies but the log said failed
                comment out the other cal definitions, so only that one is active
                /* …*/ is comment block
                • T
                  theaddies
                  I removed all calendars but the work one. It just says “Loading …”.
                  0|MagicMir | [2025-04-12 08:59:19.015] [LOG]   No helper found for module: calendar_monthly.
                  0|MagicMir | [2025-04-12 08:59:19.316] [LOG]   Module helper loaded: calendar
                  0|MagicMir | [2025-04-12 08:59:22.922] [LOG]   Connecting socket for: calendar
                  0|MagicMir | [2025-04-12 08:59:22.925] [LOG]   Starting node helper for: calendar
                  0|MagicMirror  | [2025-04-12 08:59:32.795] [LOG]   Create new calendarfetcher for url: https://x.com/remote.php/dav/calendars/admin/work?export - Interval: 3600000
                  0|MagicMirror  | [2025-04-12 08:59:34.361] [INFO]  Checking git for module: calendar_monthly
                  0|MagicMirror  | [2025-04-12 09:00:47.009] [INFO]  Calendar-Fetcher: Broadcasting 486 events from https://x.com/remote.php/dav/calendars/admin/work?export.
                  The config file is below.
                                          header: "Work",
                                          position: "top_left",   // This can be any of the regions. Best results in left or right regions.
                                                  //colored: true,
                                                  //coloredSymbolOnly: true,
                                                  //limitDays1
                                                          url: 'https://x.com/remote.php/dav/calendars/admin/work?expor>
                                                          //symbol: 'briefcase',
                                                          auth: {
        user: 'admin',
        pass: 'xxxxxx',
        method: 'basic'
                                                          maximumEntries: 5,
                  //                                        maximumNumberOfDays: 4,
                    sdetweil @theaddies
                    @theaddies ok, can you open the developers window
                    ctrl-shift-i, select the console tab, and entry cal in the filter field
                    see if there is any error?
                    maximumEntries:5 could be limiting too
                    • T
                      theaddies @sdetweil
                      @sdetweil I am only using ssh. I will plug a keyboard into it.
                      • T
                        theaddies @sdetweil
                        @sdetweil OK, so in the console I do see the message below over and over and over. That is the only thing that appears odd to me.
                        slicing events total maxcount = 10   Calendar_js:744
                        sorting events count =0 Calendar_js: 704
                          sdetweil @theaddies
                          @theaddies this sounds like v 2.30, w the clipping problem
                          https://forum.magicmirror.builders/topic/19282/version-2.30.0-calendar-fix-for-clipping-broadcast-events
                          fixed in 2.31
                          • T
                            theaddies @sdetweil
                            @sdetweil I switched to the branch described in the other post and nothing changed. I switched back to main and I give up. Thanks very much for the help. I really appreciate it.
                              sdetweil @theaddies
                              @theaddies the 2.30 fix branch isn’t there unless you manually install it
                              • T
                                theaddies @sdetweil
                                @sdetweil I did this. Nothing changed.
                                git fetch origin pull/3679/head:_fix_clipping
                                git switch _fix_clipping
                                npm run install-mm
                                # if you get an error error, rm package-lock.json
                                # and repeat the git switch
                                restart MM
                                  sdetweil @theaddies
        maximumEntries: 5,
                                  if you try 100 instead of 5 does it make a difference?
