    Nextcloud calendar error
    15 Posts 2 Posters 6.8k Views 2 Watching
    • T
      theaddies @theaddies
      @sdetweil Thanks for the reply. Nope, not old events. 2 of the calendars have loaded. The work calendar just says “Loading …” on the Pi.
        sdetweil @theaddies
        @theaddies but the log said failed
        comment out the other cal definitions, so only that one is active
        /* …*/ is comment block
        • T
          theaddies
          I removed all calendars but the work one. It just says “Loading …”.
          0|MagicMir | [2025-04-12 08:59:19.015] [LOG]   No helper found for module: calendar_monthly.
          0|MagicMir | [2025-04-12 08:59:19.316] [LOG]   Module helper loaded: calendar
          0|MagicMir | [2025-04-12 08:59:22.922] [LOG]   Connecting socket for: calendar
          0|MagicMir | [2025-04-12 08:59:22.925] [LOG]   Starting node helper for: calendar
          0|MagicMirror  | [2025-04-12 08:59:32.795] [LOG]   Create new calendarfetcher for url: https://x.com/remote.php/dav/calendars/admin/work?export - Interval: 3600000
          0|MagicMirror  | [2025-04-12 08:59:34.361] [INFO]  Checking git for module: calendar_monthly
          0|MagicMirror  | [2025-04-12 09:00:47.009] [INFO]  Calendar-Fetcher: Broadcasting 486 events from https://x.com/remote.php/dav/calendars/admin/work?export.
          The config file is below.
                                  header: "Work",
                                  position: "top_left",   // This can be any of the regions. Best results in left or right regions.
                                          //colored: true,
                                          //coloredSymbolOnly: true,
                                          //limitDays1
                                                  url: 'https://x.com/remote.php/dav/calendars/admin/work?expor>
                                                  //symbol: 'briefcase',
                                                  auth: {
                                                              user: 'admin',
                                                              pass: 'xxxxxx',
                                                              method: 'basic'
                                                  maximumEntries: 5,
          //                                        maximumNumberOfDays: 4,
          S 2 Replies Last reply
            sdetweil @theaddies
            @theaddies ok, can you open the developers window
            ctrl-shift-i, select the console tab, and entry cal in the filter field
            see if there is any error?
            maximumEntries:5 could be limiting too
            T 2 Replies Last reply
            • T
              theaddies @sdetweil
              @sdetweil I am only using ssh. I will plug a keyboard into it.
              • T
                theaddies @sdetweil
                @sdetweil OK, so in the console I do see the message below over and over and over. That is the only thing that appears odd to me.
                slicing events total maxcount = 10   Calendar_js:744
                sorting events count =0 Calendar_js: 704
                  sdetweil @theaddies
                  @theaddies this sounds like v 2.30, w the clipping problem
                  https://forum.magicmirror.builders/topic/19282/version-2.30.0-calendar-fix-for-clipping-broadcast-events
                  fixed in 2.31
                  T 1 Reply Last reply
                  • T
                    theaddies @sdetweil
                    @sdetweil I switched to the branch described in the other post and nothing changed. I switched back to main and I give up. Thanks very much for the help. I really appreciate it.
                      sdetweil @theaddies
                      @theaddies the 2.30 fix branch isn’t there unless you manually install it
                      • T
                        theaddies @sdetweil
                        @sdetweil I did this. Nothing changed.
                        git fetch origin pull/3679/head:_fix_clipping
                        git switch _fix_clipping
                        npm run install-mm
                        # if you get an error error, rm package-lock.json
                        # and repeat the git switch
                        restart MM
                          sdetweil @theaddies
                          @theaddies said in Nextcloud calendar error:
                                                              maximumEntries: 5,
                          if you try 100 instead of 5 does it make a difference?
