    Error when updating MagicMirror
    3 Posts 2 Posters 736 Views 2 Watching
    • B
      bebetter14
      Trying to update my mirror. After running git pull && npm run install-mm, I get the following error below. Now my MM wont even boot. Not sure what I messed up. Anything I can do to reset this?
      npm ERR! code EBADENGINE
      npm ERR! engine Unsupported engine
      npm ERR! engine Not compatible with your version of node/npm: magicmirror@2.31.0
      npm ERR! notsup Not compatible with your version of node/npm: magicmirror@2.31.0
      npm ERR! notsup Required: {“node”:“>=22.14.0”}
      npm ERR! notsup Actual: {“npm”:“10.1.0”,“node”:“v20.8.0”}
        sdetweil @bebetter14
        @bebetter14 yes, the release says we need node version 22.14 or higher, you have node 20.8
        easiest is to run the upgrade script (always)
        see
        the upgrade script is a 2 step approach
        1. test - make no changes - dont kill users mirror
        2. do the upgrade
        because you are part way, you have to use
        force
        as the parm instead of
        apply
        on the second pass
        because i wont let you upgrade OVER the same version .
        • B
          bebetter14
          Thank you! This worked.
