    OpenWeatherForcast - AggregateError?
    18 Posts 2 Posters 2.4k Views 2 Watching
      sdetweil @cricket
      @cricket no, only for this module…
      I can recreate here with my apikey and location and see the working direct url
      did take quite a while…
      we have the fetch timeout set to 30 seconds, so that shouldn’t be it
      • C Offline
        cricket @sdetweil
        I am going to reinstall the module as well to see if that works. Update: No change - still loading.
                                module: "MMM-OpenWeatherForecast",
                                header: "Forecast",
                                  apikey: "mykey", //only string here
                                  latitude: 43.030099,            //number works here
                                  longitude: -89.449056          //so does a string
          sdetweil @cricket
          @cricket the ‘Loading’ error means the front end (displaying data) is waiting for the data to arrive from the backend (node_helper.js)
          almost NO module reports and handles critical failures like this.
          so we asked for data, and nothing… still wating…
          I upgraded nodejs, electron and still fails in same place.
          C 2 Replies Last reply Reply Quote 1
          • C Offline
            cricket @sdetweil
            I follow some of what you have said. Thanks for your help. Hopefully it is something that can be corrected.
            • C Offline
              cricket @sdetweil
              @sdetweil said in OpenWeatherForcast - AggregateError?:
              Does this mean you are having the same issue I am?
                sdetweil @cricket
                @cricket yes, I said I could recreate your problem.
                https://forum.magicmirror.builders/post/126268
                C 1 Reply Last reply Reply Quote 1
                • C Offline
                  cricket @sdetweil
                  @sdetweil Not sure what happened, but it just started working for me… Now on to some configuration. Many thanks for all your help.
                    sdetweil @cricket
                    @cricket awesome!!
