    OpenWeatherForcast - AggregateError?
    18 Posts 2 Posters 3.5k Views 2 Watching
      sdetweil @cricket
      @cricket should be rename the old, install the new.
      no required change in config
        cricket @sdetweil
        @sdetweil Thanks for all your help. Installed this today - Still stuck at loading - this is the error I got.
        0|MagicMirror  | [2025-05-06 09:08:47.933] [ERROR] [MMM-OpenWeatherForecast] 6-May-25 09:08 ** ERROR ** TypeError: fetch failed
        0|MagicMirror  | TypeError: fetch failed
        0|MagicMirror  |     at node:internal/deps/undici/undici:13502:13
        0|MagicMirror  |     at process.processTicksAndRejections (node:internal/process/task_queues:105:5)
        I renamed the old MMM module prior to installation. I can make direct API calls in a browser using the API key provided. Not sure what to try now. Any help welcomed.
          sdetweil @cricket
          @cricket hmm… can you shown the startup info
          like this from MM startup
          ### SYSTEM:   manufacturer: System manufacturer; model: System Product Name; virtual: false
          ### OS:       platform: linux; distro: Ubuntu; release: 22.04.5 LTS; arch: x64; kernel: 5.15.0-138-generic
          ### VERSIONS: electron: 35.1.5; used node: 22.14.0; installed node: 22.14.0; npm: 10.9.2; pm2: 5.4.3
          ### OTHER:    timeZone: Europe/London; ELECTRON_ENABLE_GPU: undefined
          C 1 Reply Last reply
            cricket @sdetweil
            @sdetweil Thanks for all your help - here is what I have -
            0|MagicMir | [2025-05-06 10:28:53.242] [INFO]  System information:
            0|MagicMir | ### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.5; virtual: false
            0|MagicMir | ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.25+rpt-rpi-v8
            0|MagicMir | ### VERSIONS: electron: 35.2.2; used node: 22.14.0; installed node: 22.14.0; npm: 10.9.2; pm2: 5.4.3
            0|MagicMir | ### OTHER:    timeZone: America/Chicago; ELECTRON_ENABLE_GPU: undefined
              sdetweil @cricket
              @cricket @wishmaster270 will have to reply
              (I know he has been busy, so may take some time)
              can you post your module config,
              xxx out the apikey
              and I can try it
                cricket @sdetweil
                @sdetweil Copy that - I have also tried the API web call on the pi browser - it works fine. I tried a couple of options.
                Are you asking me to post the entire conifg.js?
                Thanks.
                  sdetweil @cricket
                  @cricket no, only for this module…
                  I can recreate here with my apikey and location and see the working direct url
                  did take quite a while…
                  we have the fetch timeout set to 30 seconds, so that shouldn’t be it
                    cricket @sdetweil
                    I am going to reinstall the module as well to see if that works. Update: No change - still loading.
                                            module: "MMM-OpenWeatherForecast",
                                            header: "Forecast",
                                              apikey: "mykey", //only string here
                                              latitude: 43.030099,            //number works here
                                              longitude: -89.449056          //so does a string
                      sdetweil @cricket
                      @cricket the ‘Loading’ error means the front end (displaying data) is waiting for the data to arrive from the backend (node_helper.js)
                      almost NO module reports and handles critical failures like this.
                      so we asked for data, and nothing… still wating…
                      I upgraded nodejs, electron and still fails in same place.
                      C 2 Replies Last reply
                        cricket @sdetweil
                        I follow some of what you have said. Thanks for your help. Hopefully it is something that can be corrected.
                          cricket @sdetweil
                          @sdetweil said in OpenWeatherForcast - AggregateError?:
                          Does this mean you are having the same issue I am?
                            sdetweil @cricket
                            @cricket yes, I said I could recreate your problem.
                            https://forum.magicmirror.builders/post/126268
                              cricket @sdetweil
                              @sdetweil Not sure what happened, but it just started working for me… Now on to some configuration. Many thanks for all your help.
                                sdetweil @cricket
                                @cricket awesome!!
