OpenWeatherForcast - AggregateError?
18 Posts 2 Posters 1.1k Views 2 Watching
    cricket
    New 1st time MM setup today. trying to use the jclarke MMM-OpenWeatherForecast module. I keep getting “MMM-OpenWeatherForecast] 5-May-25 18:28 ** ERROR ** AggregateError”. I have purchased the correct Open Call API and I can make web querry with success. Here is my simple module. Any help?
                      module: "MMM-OpenWeatherForecast",
                      header: "Forecast",
                        apikey: "XXXXXX", //SUPER SECRET
                        latitude: "23.073051",
                        longitude: "-41.401230"
    S 1 Reply Last reply May 6, 2025, 1:45 AM Reply Quote 0
      sdetweil @cricket
      @cricket you should use the updated version from Tom
      https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast
      C 2 Replies Last reply May 6, 2025, 1:59 AM Reply Quote 1
        cricket @sdetweil
        @sdetweil Thank you for this - I may give that a go tomorrow.
        S 2 Replies Last reply May 6, 2025, 2:08 AM Reply Quote 0
          sdetweil @cricket
          @cricket always look thru the 3rd party list (linked above, got good search), take the newest of same name
            sdetweil @cricket
            @cricket should be rename the old, install the new.
            no required change in config
              cricket @sdetweil
              @sdetweil Thanks for all your help. Installed this today - Still stuck at loading - this is the error I got.
              0|MagicMirror  | [2025-05-06 09:08:47.933] [ERROR] [MMM-OpenWeatherForecast] 6-May-25 09:08 ** ERROR ** TypeError: fetch failed
              0|MagicMirror  | TypeError: fetch failed
              0|MagicMirror  |     at node:internal/deps/undici/undici:13502:13
              0|MagicMirror  |     at process.processTicksAndRejections (node:internal/process/task_queues:105:5)
              I renamed the old MMM module prior to installation. I can make direct API calls in a browser using the API key provided. Not sure what to try now. Any help welcomed.
              S 1 Reply Last reply May 6, 2025, 2:23 PM Reply Quote 0
                sdetweil @cricket
                @cricket hmm… can you shown the startup info
                like this from MM startup
                ### SYSTEM:   manufacturer: System manufacturer; model: System Product Name; virtual: false
                ### OS:       platform: linux; distro: Ubuntu; release: 22.04.5 LTS; arch: x64; kernel: 5.15.0-138-generic
                ### VERSIONS: electron: 35.1.5; used node: 22.14.0; installed node: 22.14.0; npm: 10.9.2; pm2: 5.4.3
                ### OTHER:    timeZone: Europe/London; ELECTRON_ENABLE_GPU: undefined
                C 1 Reply Last reply May 6, 2025, 3:33 PM Reply Quote 0
                  cricket @sdetweil
                  @sdetweil Thanks for all your help - here is what I have -
                  0|MagicMir | [2025-05-06 10:28:53.242] [INFO]  System information:
                  0|MagicMir | ### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.5; virtual: false
                  0|MagicMir | ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.25+rpt-rpi-v8
                  0|MagicMir | ### VERSIONS: electron: 35.2.2; used node: 22.14.0; installed node: 22.14.0; npm: 10.9.2; pm2: 5.4.3
                  0|MagicMir | ### OTHER:    timeZone: America/Chicago; ELECTRON_ENABLE_GPU: undefined
                  S 1 Reply Last reply May 6, 2025, 4:35 PM Reply Quote 0
                    sdetweil @cricket
                    @cricket @wishmaster270 will have to reply
                    (I know he has been busy, so may take some time)
                    can you post your module config,
                    xxx out the apikey
                    and I can try it
                    C 1 Reply Last reply May 6, 2025, 5:12 PM Reply Quote 0
                      cricket @sdetweil
                      @sdetweil Copy that - I have also tried the API web call on the pi browser - it works fine. I tried a couple of options.
                      Are you asking me to post the entire conifg.js?
                      Thanks.
                      S 1 Reply Last reply May 6, 2025, 5:31 PM Reply Quote 0
