    OpenWeatherForcast - AggregateError?
    18 Posts 2 Posters 2.3k Views 2 Watching
      cricket @sdetweil
      @sdetweil Thanks for all your help. Installed this today - Still stuck at loading - this is the error I got.
      0|MagicMirror  | [2025-05-06 09:08:47.933] [ERROR] [MMM-OpenWeatherForecast] 6-May-25 09:08 ** ERROR ** TypeError: fetch failed
      0|MagicMirror  | TypeError: fetch failed
      0|MagicMirror  |     at node:internal/deps/undici/undici:13502:13
      0|MagicMirror  |     at process.processTicksAndRejections (node:internal/process/task_queues:105:5)
      I renamed the old MMM module prior to installation. I can make direct API calls in a browser using the API key provided. Not sure what to try now. Any help welcomed.
        sdetweil @cricket
        @cricket hmm… can you shown the startup info
        like this from MM startup
        ### SYSTEM:   manufacturer: System manufacturer; model: System Product Name; virtual: false
        ### OS:       platform: linux; distro: Ubuntu; release: 22.04.5 LTS; arch: x64; kernel: 5.15.0-138-generic
        ### VERSIONS: electron: 35.1.5; used node: 22.14.0; installed node: 22.14.0; npm: 10.9.2; pm2: 5.4.3
        ### OTHER:    timeZone: Europe/London; ELECTRON_ENABLE_GPU: undefined
          cricket @sdetweil
          @sdetweil Thanks for all your help - here is what I have -
          0|MagicMir | [2025-05-06 10:28:53.242] [INFO]  System information:
          0|MagicMir | ### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.5; virtual: false
          0|MagicMir | ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.25+rpt-rpi-v8
          0|MagicMir | ### VERSIONS: electron: 35.2.2; used node: 22.14.0; installed node: 22.14.0; npm: 10.9.2; pm2: 5.4.3
          0|MagicMir | ### OTHER:    timeZone: America/Chicago; ELECTRON_ENABLE_GPU: undefined
            sdetweil @cricket
            @cricket @wishmaster270 will have to reply
            (I know he has been busy, so may take some time)
            can you post your module config,
            xxx out the apikey
            and I can try it
              cricket @sdetweil
              @sdetweil Copy that - I have also tried the API web call on the pi browser - it works fine. I tried a couple of options.
              Are you asking me to post the entire conifg.js?
              Thanks.
                sdetweil @cricket
                @cricket no, only for this module…
                I can recreate here with my apikey and location and see the working direct url
                did take quite a while…
                we have the fetch timeout set to 30 seconds, so that shouldn’t be it
                  cricket @sdetweil
                  I am going to reinstall the module as well to see if that works. Update: No change - still loading.
                                          module: "MMM-OpenWeatherForecast",
                                          header: "Forecast",
                                            apikey: "mykey", //only string here
                                            latitude: 43.030099,            //number works here
                                            longitude: -89.449056          //so does a string
                    sdetweil @cricket
                    @cricket the ‘Loading’ error means the front end (displaying data) is waiting for the data to arrive from the backend (node_helper.js)
                    almost NO module reports and handles critical failures like this.
                    so we asked for data, and nothing… still wating…
                    I upgraded nodejs, electron and still fails in same place.
                    C 2 Replies Last reply Reply Quote 1
                      cricket @sdetweil
                      I follow some of what you have said. Thanks for your help. Hopefully it is something that can be corrected.
                        cricket @sdetweil
                        @sdetweil said in OpenWeatherForcast - AggregateError?:
                        Does this mean you are having the same issue I am?
