    Can updatenotification be configured to restart the main MM process?
    5 Posts 2 Posters 681 Views 2 Watching
    • K Offline
      khrusher
      I have updatenotification configured with update commands to perform module specific updates.
            "module":"updatenotification",
               "position":"top_center",
               "config":{
                    updates:
                         "MMM-MyStandings": "git pull",
                         "MMM-MyScoreboard": "git pull && npm install --omit=dev",
      is there way to configure a MM restart command in response to a “restart required” notification?
           pm2 restart MM
        sdetweil @khrusher
        @khrusher yes. it can only restart w pm2 and knows which app to restart
        • K Offline
          khrusher @sdetweil
          Ok, I read that parameter as ‘restart once one of the modules in the Updates array are updated’
          So updateAutorestart is based on general MM updates.
          How does it know the name of the app to restart?
          does it run
          mp2 restart all
            sdetweil @khrusher
            @khrusher one can determine the path of the running app
            • K Offline
              khrusher @sdetweil
              @sdetweil nice. how do I mark item as ‘Resolved’?
              I found it!
              • K khrusher has marked this topic as solved on
