    Voice and Touch control modules
    13 Posts 3 Posters 2.3k Views 3 Watching
      sdetweil @sankum
      @sankum we had a really good google assistant, but the author left and took all his modules down.
      not much work was done on others for quite a while
        sankum
        Hi Sam,
        I clones a MMM-GoogleAssistant. When I run it it complains about speaker module not found:
        [ERROR] Error when loading MMM-GoogleAssistant: Cannot find module ‘speaker’
        Require stack:
        • /home/sankum/MagicMirror/modules/MMM-GoogleAssistant/node_helper.js
        • /home/sankum/MagicMirror/js/app.js
        • /home/sankum/MagicMirror/js/electron.js
        Is there something missing or I need to install something else? Thanks.
          sdetweil @sankum
          @sankum where is that module sourced from
          git remote -v
          in the module folder
            sankum
            Hi Sam,
            Following is the source:
            sankum@rpi:~/MagicMirror/modules/MMM-GoogleAssistant $ git remote -v
            origin https://github.com/jeffmur/MMM-GoogleAssistant.git (fetch)
            origin https://github.com/jeffmur/MMM-GoogleAssistant.git (push)
              sdetweil @sankum
              @sankum yeh, I don’t know.
              speaker still exists
              https://www.npmjs.com/package/speaker
              the module was last updated 4 years ago, so who knows…
                sankum
                Thanks. But clearly something is outdated? Snippets of error messages below. Does not install. Is it simply old version or something can be done to salvage or anu other alternative? Thanks.
                ://eslint.org/version-support for other options.
                npm error code 1
                npm error path /home/sankum/MagicMirror/modules/node-speaker/node_modules/speaker
                npm error command failed
                npm error command sh -c node-gyp rebuild
                npm error make: Entering directory ‘/home/sankum/MagicMirror/modules/node-speaker/node_modules/speaker/build’
                npm error CC(target) Release/obj.target/output/deps/mpg123/src/output/alsa.o
                npm error make: Leaving directory ‘/home/sankum/MagicMirror/modules/node-speaker/node_modules/speaker/build’
                npm error gyp info it worked if it ends with ok
                npm error gyp info using node-gyp@11.0.0
                npm error gyp info using node@22.16.0 | linux | arm64
                  sdetweil @sankum
                  @sankum the working alternative no longer exists.
                  there is no author commitment to maintain their module contributions. if you care/want/can resurrect a module, more power to you.
                  here is the story on Alexa
                  https://forum.magicmirror.builders/topic/16069/alexa-implementations-now-more-difficult-and-some-features-will-stop-working
                    sankum
                    Thanks. If I had the skills I certainly will endeavor to do so. So for now may not be able to use Voice after all.
                    What would be another way to see future months in the Calendar when it is set as a display, say on the wall? Using mouse? Thanks.
                      sdetweil @sankum
                      @sankum i use mmm-pages, and 3 instances of MMM-Calendarext3 one for current month, next and after.
                      some have added swipe to that, so you can wave a hand, with the right sensor
                      page-indicator module can give you on screen buttons for direct page access too (assuming you have touch support, built in or ir frane)
