    Voice and Touch control modules
    13 Posts 3 Posters 4.2k Views 3 Watching
      sdetweil @sankum
      @sankum there are currently no good working voice modules for MagicMirror
      touch is limited. MagicMirror was designed as an output only information panel, on a device with no touch support.
      there are a couple modules that provide some touch support
      search the 3rd party list, but nothing really MagicMirror controlling. maybe swipe to change logical pages w mmm-pages or carousel
      or more recently
      https://forum.magicmirror.builders/topic/19678/mmm-chores-manage-and-keep-track-of-your-household-chores
      MagicMirror runs in a web browser, so if your display supports touch, its possible to write more modules that support touch
        Ashaman @sankum
        @sankum
        I searched for the same, but did not find anything that worked for me (not saying there is not anything out there, just did not fit my need).
        I have a 43" touch mirror (repurposed fitness smart mirror), and currently I have a WIP solution with a custom browser coded in python, that only display a menu icon in the top. In it I can open a menu for refreshing the page, restart the Docker container my MM is in, open and edit the config, git-pull any modules etc.
        I can also predefine the tabs is should load, so main tab is MM-url, second is Homey-url, so I can control my Homey devices from the screen.
        I also have a custom (not released) module for showing “MM-tabs” with icons in the bottom of the screen, based on the MMM-Carousel module.
        This way I can swipe “pages”, or just click a tab and it switches to that “page”.
        Tripple tapping a tab deactivate the tab If i dont want to show it.
        The repos for this is currently privat, as they are still WIP, but I’m probably going to publish them at some point.
          sankum
          Thanks for your feedback. Looking forward to your Touchscreen module demo.!
          I have been looking into MMM-Jarvis-Voice-Control. Have installed it but not gotten it to work. The documentation for installation and plugins is not great.
          Anybody else had experience with this module? Is it worth pursuing to make it work?
            sdetweil @sankum
            @sankum we had a really good google assistant, but the author left and took all his modules down.
            not much work was done on others for quite a while
              sankum
              Hi Sam,
              I clones a MMM-GoogleAssistant. When I run it it complains about speaker module not found:
              [ERROR] Error when loading MMM-GoogleAssistant: Cannot find module ‘speaker’
              Require stack:
              • /home/sankum/MagicMirror/modules/MMM-GoogleAssistant/node_helper.js
              • /home/sankum/MagicMirror/js/app.js
              • /home/sankum/MagicMirror/js/electron.js
              Is there something missing or I need to install something else? Thanks.
                sdetweil @sankum
                @sankum where is that module sourced from
                git remote -v
                in the module folder
                  sankum
                  Hi Sam,
                  Following is the source:
                  sankum@rpi:~/MagicMirror/modules/MMM-GoogleAssistant $ git remote -v
                  origin https://github.com/jeffmur/MMM-GoogleAssistant.git (fetch)
                  origin https://github.com/jeffmur/MMM-GoogleAssistant.git (push)
                    sdetweil @sankum
                    @sankum yeh, I don’t know.
                    speaker still exists
                    https://www.npmjs.com/package/speaker
                    the module was last updated 4 years ago, so who knows…
                      sankum
                      Thanks. But clearly something is outdated? Snippets of error messages below. Does not install. Is it simply old version or something can be done to salvage or anu other alternative? Thanks.
                      ://eslint.org/version-support for other options.
                      npm error code 1
                      npm error path /home/sankum/MagicMirror/modules/node-speaker/node_modules/speaker
                      npm error command failed
                      npm error command sh -c node-gyp rebuild
                      npm error make: Entering directory ‘/home/sankum/MagicMirror/modules/node-speaker/node_modules/speaker/build’
                      npm error CC(target) Release/obj.target/output/deps/mpg123/src/output/alsa.o
                      npm error make: Leaving directory ‘/home/sankum/MagicMirror/modules/node-speaker/node_modules/speaker/build’
                      npm error gyp info it worked if it ends with ok
                      npm error gyp info using node-gyp@11.0.0
                      npm error gyp info using node@22.16.0 | linux | arm64
                        sdetweil @sankum
                        @sankum the working alternative no longer exists.
                        there is no author commitment to maintain their module contributions. if you care/want/can resurrect a module, more power to you.
                        here is the story on Alexa
                        https://forum.magicmirror.builders/topic/16069/alexa-implementations-now-more-difficult-and-some-features-will-stop-working
                          sankum
                          Thanks. If I had the skills I certainly will endeavor to do so. So for now may not be able to use Voice after all.
                          What would be another way to see future months in the Calendar when it is set as a display, say on the wall? Using mouse? Thanks.
                            sdetweil @sankum
                            @sankum i use mmm-pages, and 3 instances of MMM-Calendarext3 one for current month, next and after.
                            some have added swipe to that, so you can wave a hand, with the right sensor
                            page-indicator module can give you on screen buttons for direct page access too (assuming you have touch support, built in or ir frane)
