    MMM-NASCARPoints not showing in my display
    2 Posts 2 Posters 483 Views 2 Watching
    • B
      brmfulasha
      so this is my first repo and it runs ok but it doesnt seem to show up on my magicmirror and im at a loss. can anyone help me if its a coding issue or my setup?
      https://github.com/brmfulasha/MMM-NASCARPoints
      thanks
      Nick
        sdetweil @brmfulasha
        @brmfulasha
        so you add console log to the node_helper
        then you can verify it got the data and sent it to the module
        then you can use the developers window sources tab to debug the browser side
        i dont see anything obvious
        you dont need to set the module name on the wrapper
        as the module entry had that classname
        you can use the developers window elements tab to look at your content
        see the second link in my signature below for a starter on the dev window elements tab
