    Calvin and Hobbs
    18 Posts 3 Posters 3.5k Views 3 Watching
    • plainbrokeP Offline
      plainbroke @karsten13
      @karsten13
      Thank you so very much for your work.
      I did have to restore the original css file from the original builder of this module.
      So I could get the full screen to work. Other wise it works so great now.
      My wife is very pleased.
      Thank you again for your great work…
      Just Jeff
      • karsten13K Online
        karsten13 @plainbroke
        @plainbroke said in Calvin and Hobbs:
        hm, did I fork from the wrong repo?
        If you share a link to the original file you mentioned I can update it on my fork.
        plainbrokeP 1 Reply Last reply Reply Quote 0
          @karsten13
          No you did not fork from the wrong repo, someone merged the two repo’s so they where the same I have the full original that i backed up the files to my nas drive.
          I do not know how to send them to you or even share them. Not sure why the css was changed either. If it is not to technical I could try to load it somewhere on here for you…
          • karsten13K Online
            you could publish the content of the file here as text using a code block
            content
              @karsten13
              The original cahcomic.css contains only this.
              Hope this helps you. I am not very good with all this code stuff.
              Mainly I do it through trial and error.
              /* The basic container */
              .cahcomiccontainer {
                  overflow: hidden;
                  /* To make the height of the container exact. */
                  -webkit-box-sizing: border-box;
                  -moz-box-sizing: border-box;
              #cahcomiccontent {
                white-space: nowrap;
                position: relative;
                overflow: hidden;    /* Required to make ellipsis work */
                text-overflow: clip;
                top: 0%;
                -webkit-transition: top 3s, height 3s;
                -moz-transition: top 3s, height 3s;
              plainbrokeP karsten13K 2 Replies Last reply Reply Quote 0
                plainbroke @plainbroke
                Hopefully you can tell it fills my screen and is todays Monday June 9 2025’s
                comic. We really love this comic, both my wife and I are big fans of Calvin and Hobbs comic. I really appreciate the help you provided getting the comic back to working form for us… Keep up the great work you are appreciated…
                • karsten13K Online
                  I updated my fork with the original css, for updating go into the module folder and do
                  # remove all changed stuff in this repo out of the way:
                  git reset --hard
                  # pull new version:
                  git pull
                    @karsten13
                    Done, Thank you. Working like it should now.
