    Calvin and Hobbs
    18 Posts 3 Posters 4.9k Views 3 Watching
    • plainbrokeP Offline
      plainbroke @sdetweil
      I am hoping that B3DTech will jump in and help me fix this he had it working for a while. Do you think since it requires a subscription on that page now, that we will not be able to scape the cartoon off of that page anymore?
        sdetweil @plainbroke
        @plainbroke got no idea. Away from my system so can’t look at the page contents
          @plainbroke try this
          using this version https://github.com/B3DTech/MMM-CalvinAndHobbes.git
          in the node_helper.js
          comment out this line
                      const $ = cheerio.load(html);
                      //$('div[class^="ShowFiveFavorites"]').remove(); <----- comment out like this
          must restart MM as the node_helper is loaded only at MM startup time
            Well that brought back the screen I have been stuck on, (that does not update)., I think it is the comic from april 3rd 2025, and now it is scrunched up at the top of my screen instead of filling the screen.
            Too weird how that one line does that.
            .MMM-CalvinAndHobbes .module-content {
                    Margin-top: 10px;
                    Margin-left: 10px;
                    max-width: 1810px;
                    max-height: 1025px;
                    width: 1810px;
                    height: 1025px;
                    overflow: hidden;
            #cahcomiccontent {
                    width: 1810px;
                    height: 1025px;
            Is what I have had in my custom.css for a long time to show the comic full screen.
            That took a lot of tweaking to get just right.
              @plainbroke i click the screen and it goes to center
              i dont see why the image is scrunched and stretched
              this is all the time i can invest in this
              plainbrokeP 1 Reply Last reply Reply Quote 1
                That is ok, really.
                I am burnt out too trying to get it up and running myself.
                I am thinking unless someone else wants to put a bunch of time in to figuring out what changed. I am done with this one.
                I do appreciate the time you have invested in trying to figure it out…
                Thank you very much for your help…
                I will mark it resolved.
                • plainbrokeP plainbroke has marked this topic as solved on
                • karsten13K Offline
                  karsten13 @plainbroke
                  @plainbroke
                  invested some time to grab the comic url, you can try my fork.
                    plainbroke @karsten13
                    @karsten13
                    Thank you so very much for your work.
                    I did have to restore the original css file from the original builder of this module.
                    So I could get the full screen to work. Other wise it works so great now.
                    My wife is very pleased.
                    Thank you again for your great work…
                    Just Jeff
                      @plainbroke said in Calvin and Hobbs:
                      hm, did I fork from the wrong repo?
                      If you share a link to the original file you mentioned I can update it on my fork.
                        @karsten13
                        No you did not fork from the wrong repo, someone merged the two repo’s so they where the same I have the full original that i backed up the files to my nas drive.
                        I do not know how to send them to you or even share them. Not sure why the css was changed either. If it is not to technical I could try to load it somewhere on here for you…
                          you could publish the content of the file here as text using a code block
                          content
                            @karsten13
                            The original cahcomic.css contains only this.
                            Hope this helps you. I am not very good with all this code stuff.
                            Mainly I do it through trial and error.
                            /* The basic container */
                            .cahcomiccontainer {
                                overflow: hidden;
                                /* To make the height of the container exact. */
                                -webkit-box-sizing: border-box;
                                -moz-box-sizing: border-box;
                            #cahcomiccontent {
                              white-space: nowrap;
                              position: relative;
                              overflow: hidden;    /* Required to make ellipsis work */
                              text-overflow: clip;
                              top: 0%;
                              -webkit-transition: top 3s, height 3s;
                              -moz-transition: top 3s, height 3s;
                            plainbrokeP karsten13K 2 Replies Last reply Reply Quote 0
                              plainbroke @plainbroke
                              Hopefully you can tell it fills my screen and is todays Monday June 9 2025’s
                              comic. We really love this comic, both my wife and I are big fans of Calvin and Hobbs comic. I really appreciate the help you provided getting the comic back to working form for us… Keep up the great work you are appreciated…
                                I updated my fork with the original css, for updating go into the module folder and do
                                # remove all changed stuff in this repo out of the way:
                                git reset --hard
                                # pull new version:
                                git pull
                                  @karsten13
                                  Done, Thank you. Working like it should now.
