    need help installing MMPM - losing my mind
    11 Posts 4 Posters 2.2k Views 5 Watching
    • C Offline
      Cote289
      Hello new user here.
      trying to setup a magic mirror for my wife.
      got the hardware and MM installed and now i’m trying to install some modules to get it set up.
      MMPM seems like a good first one to help get all the modules setup correctly but I cannot for the life of me get it working
      I’m good with computers but a bit of a noob for linux and rasberry pi stuff. This is my first build.
      Per the instructions I can install it via docker and I run that command
      docker pull karsten13/mmpm
      that seems to run and do its thing but its not installed.
      so I try the python method listed
      python3 -m pip install --upgrade mmpm
      Here’s where I get this error:
      error: externally-managed-environment
      This environment is externally managed
      To install Python packages system-wide, try apt install
      python3-xyz, where xyz is the package you are trying to
      install.
      If you wish to install a non-Debian-packaged Python package,
      create a virtual environment using python3 -m venv path/to/venv.
      Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
      sure you have python3-full installed.
      For more information visit http://rptl.io/venv
      note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
      hint: See PEP 668 for the detailed specification.
      Please help!
      what do I do to install this module to set up my magic mirror?
      thank you all in advance
      Ben
      S KristjanESPERANTOK 4 Replies Last reply Reply Quote 0
        sdetweil @Cote289
        @Cote289 i do not know, never having been successful myself
        you could try my MMM-Config module which also supports installing modules and provides full MagicMirror config
        https://github.com/sdetweil/MMM-Config
        all js and shell script
        • KristjanESPERANTOK Offline
          KristjanESPERANTO Module Developer @Cote289
          mmpm is a cool project.
          Instead this:
          This may work (I don’t have time to test it now ):
          sudo apt install pipx
          pipx install mmpm
          @bee-mar Can you help here (and maybe update your installation instructions)?
          By the way: There is also a manual (like official) way to install modules. You do not need a manager for installing modules.
            sdetweil @Cote289
            @Cote289 for manual install of modules, see the 1st link in my signature below
            • L Offline
              lmhmm
              Yes,
              I used to use the graphical interface which really liked then it stopped working. I used the python install and now it just works via command line:
              mmpm update
              Cycles through all installed modules and says if upgrades needed.
              mmpm upgrade
              Updates !
              How simple and efficient!
              Any messages I’ve had following them usually results in correcting any issues. It also updates itself.
              I’ve now come to prefer using the command line.
              Good luck! I can’t get mmconfig to work at all …
                sdetweil @lmhmm
                @lmhmm said in need help installing MMPM - losing my mind:
                If you are willing, I’d like to understand and resolve any problems you found
                • L Offline
                  lmhmm @sdetweil
                  @sdetweil Okay, I did a fresh MM install and got MMM-Config to work. However when bring up the module installer (the main reason I want MMM-Config), it takes ages to load then shows briefly. The minute I move to the search to start typing it says magic mirror installer not running … so I have to reload etc.
                  So I never get to use it … base configure comes up okay.
                  Stuck …
                    sdetweil @lmhmm
                    @lmhmm great, what device is MagicMirror running on?
                    are you opening the page on the same system?
                    over the network? (how fast, wifi, or wired)
                    I opened this issue
                    https://github.com/sdetweil/MMM-Config/issues/64
                    • L Offline
                      lmhmm @sdetweil
                      @sdetweil Okay so I’ve now completely reset my MM with the latest node and npm. Yes MMM-Config works as advertised thank you.
                        sdetweil @lmhmm
                        @lmhmm thanks for the feedback. I see the delay in loading the list on installer.
                        don’t have solution yet, the list of modules is quite long (over 1200)
