    MMM-GooglePhotos Error code 403
    2 Posts 2 Posters 569 Views 2 Watching
      Sampleswow
      Hello everyone i am not sure whats going on, recently i changed the photos in my album on google photos and usually it switches right away. well i noticed it had not so i restarted the pi and i am now getting the loading Google Photos in the bottom right corner whenever i hit Ctrl Q my log looks like this,
      [2025-06-13 12:58:36.179] [ERROR] (node:2940) UnhandledPromiseRejectionWarning: AxiosError: Request failed with status code 403
      at settle (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/dist/node/axios.cjs:2031:12)
      at Unzip.handleStreamEnd (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/dist/node/axios.cjs:3148:11)
      at Unzip.emit (node:events:530:35)
      at endReadableNT (node:internal/streams/readable:1698:12)
      at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
      at Axios.request (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/dist/node/axios.cjs:4258:41)
      at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      at async GPhotos.request (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:165:19)
      at async getAlbum (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:208:24)
      at async GPhotos.getAlbums (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:180:18)
      at async Class.getAlbums (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:263:15)
      at async Class.getAlbumList (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:313:18)
      at async Class.scanJob (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:294:5)
      [2025-06-13 12:58:36.180] [ERROR] (node:2940) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 265)
      i am not sure whats wrong of where to start i have tried googling a few key terms but not much made sense.
      This is my code line
      module: “MMM-GooglePhotos”,
      position: “fullscreen_below”,
      albums: [“MagicMirror”], // Set your album name. like [“My wedding”, “family share”, “Travle to Paris”]
      updateInterval: 1000 * 60, // minimum 10 seconds.
      sort: “random”, // “old”, “new”
      uploadAlbum: null, // Only album created by create_uploadable_album.js.
      condition: {
      fromDate: null, // Or “2018-03”, RFC … format available
      toDate: null, // Or “2019-12-25”,
      minWidth: null, // Or 400
      maxWidth: null, // Or 8000
      minHeight: null, // Or 400
      maxHeight: null, // Or 8000
      minWHRatio: null,
      maxWHRatio: null,
      // WHRatio = Width/Height ratio ( ==1 : Squared Photo, < 1 : Portraited Photo, > 1 : Landscaped Photo)
      showWidth: 1080, // These values will be used for quality of downloaded photos to show. real size to show in your MagicMirror region is recommended.
      showHeight: 1920,
      timeFormat: “YYYY/MM/DD HH:mm”, // Or relative can be used.
      this was my code before changing the photos as well.
        sdetweil @Sampleswow
        @Sampleswow see here https://forum.magicmirror.builders/post/126804
