    MMM-Wallpaper notification and MMM-ModuleScheduler
    5 Posts 2 Posters 876 Views 2 Watching
      sankum
      I am trying to use MMM-ModuleScheduler to send notification to MMM-Wallpaper for changing the source in config. However, it does not seem to change. Is there something wrong with the Scheduler as set up below:
      module: ‘MMM-ModuleScheduler’,
      schedules: [
      schedule: “0 17 * * *”,
      notification: “UPDATE_WALLPAPER_CONFIG”,
      payload: {
      module: “MMM-Wallpaper”,
      source: “chromecast”,
      No errors in running and the wallpaper module works fine but the source does not change as per the scheduler? Any help will be appreciated. Thanks.
      S 2 Replies Last reply
        sankum
        Thanks Sam.
        I had it as schedules but it has to be notification_schedule. This works now.
        Reply Quote 1
          sdetweil @sankum
          @sankum the payload should just be the string of the source name
          Dont need module name etc
          EVERY Notification goes to all modules
            sankum
            Thanks. I changed the payload to as follows:
            payload: “chromecast”
            Still the source in Wallpaper does not change?
            Anything else I should I look for?
              sdetweil @sankum
              @sankum I do not know
              Have you tried the Chromecast source directly to ensure it works?
              You could use
              My MMM-CurlToNotification
              https://github.com/sdetweil/MMM-CurlToNotification
              as a test tool to make sure the notification works
              You can also install MMM-ViewNotifications
              to see if the notification is being sent
                sankum
                Thanks Sam.
                Reply Quote 1
