    MM install script failure on fresh install of Raspian
    9 Posts 2 Posters 892 Views 2 Watching
    • unfriendlydeviceU Offline
      unfriendlydevice
      I’ve tried running sdetweil’s install script on a freshly install of Raspian but I am getting the following error:
      bash: line 288: /usr/local/bin/node: cannot execute: required file not found
      node failed to execute, please check the error message and resolve before trying again.
      Link to line 288: https://github.com/sdetweil/MagicMirror_scripts/blob/e070ce32ad1066c76bf7cca60fce144f10949783/raspberry.sh#L288
        rerun the install script again
        unfriendlydeviceU 1 Reply Last reply Reply Quote 0
          sdetweil @unfriendlydevice
          @unfriendlydevice can you send me the ~/install.log
          Same user id as here at Gmail
            unfriendlydevice @sdetweil
            @sdetweil Thanks, email sent. I forgot to mention that in my first attempt I had an internet outage when the script was updating packages.
              @unfriendlydevice got it. Busy all day, will try to look at this evening
                @unfriendlydevice I updated the installer script for the condition you found.
                I would suggest reflashing the sd card before starting
                unfriendlydeviceU 1 Reply Last reply Reply Quote 2
                  @sdetweil I reflashed my SD card but I’m afraid this has failed installing node, I’ve fowarded the new install.log to you.
                    @unfriendlydevice ok, thx will review.
                        @sdetweil Sadly another failure I’ve emailed the log.
