    MMM-JsonTable - error and does not load
    19 Posts 2 Posters 3.3k Views 2 Watching
      sankum
      I am trying to read and display from a local json file using this module.
      config:
      url: ‘https://localhost:8080/modules/MMM-JsonTable/myList.json’,
      arrayName: ‘items’,
      keepColumns: ‘name’
      I get following errors:
      [2025-06-29 19:01:30.116] [ERROR] (node:109589) UnhandledPromiseRejectionWarning: TypeError: fetch failed
      at node:internal/deps/undici/undici:13502:13
      at process.processTicksAndRejections (node:internal/process/task_queues:105:5)
      [2025-06-29 19:01:30.116] [ERROR] (node:109589) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
      myList.json in module directory -from the example on github with item and name only.
      It stays at loading with those errors.
      What am I doing wrong? Please help. Thanks.
        sankum
        Sam,
        Yes, it was the file content. I had copied it from the git example but obviously did something wrong.
          sdetweil @sankum
          @sankum unless you enable it and provide a certificate, MagicMirror is http only
          your url is https;//
            sankum
            Thanks Sam. I changed it to http:// and even tried local IP address instead of localhost and the result is the same. Still the same error, and does not load.?
              sdetweil @sankum
              @sankum if you change to a file url in a browser
              file:///home/userid/MagicMirror/modules/....
              does the file load? this proves the file path and character case
              remember linux is case sensitive
              then replace in front of /modules
              with
              http://localhost:8080
                sankum
                Hi Sam,
                file:/home/sankum/… loads with 1 slash in the browser. But nhttp://localhost:8080/modules/… does not, same errors as before?
                  sdetweil @sankum
                  @sankum is MagicMirror configured to port 8080?
                  not
                  nhttp
                  http://
                    sankum
                    Sam, MagicMirror is configured to port 8080. nhtp was a typo. It is http://…
                    As I said the file path and name are correct as I can read it in browser using file:/… (single slash). So not quite sure what is going on?
                      sdetweil @sankum
                      @sankum what is your address: setting in config.js
                        sankum
                        Sam,
                        address: “localhost”,
                          sdetweil @sankum
                          @sankum I used the sample from the readme
                            "items": [
                                "name": "Watt",
                                "value": "270 Watt"
                                "name": "Today",
                                "value": "5.85 kWh"
                                "name": "ThisWeek",
                                "value": "5.83 kWh"
                                "name": "ThisMonth",
                                "value": "12.8 kWh"
                                "name": "LastMonth",
                                "value": "246.75 kWh"
                          in the module folder
                          and this config (from the readme)
                            module: 'MMM-JsonTable',
                            position: 'top_right',
                            classes:'page1',
                            header: 'HouseDB Sevensegment',
                              url: 'http://localhost:8090/modules/MMM-JsonTable/foobar.json', // Required
                              arrayName: 'items' // Required---
                          and it displayed as expected
                            sankum
                            Thanks Sam.
                            So do I need port 8090 based on your config?. In my config port definition I have:
                            port: “8080”,
                            Other than that I don’t see any difference. Do I need to change router setting? Any missing package you think? Thanks.
                              sankum
                              Hi Sam,
                              Never mind!! It is port 8080.
                              I copied the json file you have shown and it worked. So it must be my json file. I will try to figure out what is the difference. Thanks for your help.
                                sdetweil @sankum
                                @sankum sorry intended to change that in
                                my post, too early
                                  sdetweil @sankum
                                  @sankum i use this online to to validate and format json
                                  https://codebeautify.org/jsonvalidator
                                    sankum
                                    Thank you, Sam.
                                      sdetweil @sankum
                                      @sankum did you get it fixed?
                                        sankum
                                        Sam, sorry I overlooked your question
                                        Yes, I did get it fixed. Thanks.
                                          sdetweil @sankum
                                          @sankum was it the file contents?
                                            sankum
                                            Sam,
