    mmm-calendarEXT3 multiple questions
    3 Posts 2 Posters 530 Views 2 Watching
    • R
      redux703
      Hello,
      I am new to the magic mirror scene, and am struggeling with the code for the mmm-CalendarExt3.
      The code runs when i start the magic mirror application, but google agenda doesn’t load in it (even when its on for a while ~5min)
      And in the beginning of each week is “CW 1” now I’ve read that it is current week. But how can i change it so it shows the real current week? And change the “CW” to something else?
      This it the snippet of my code:
        module: "MMM-CalendarExt3",
        position: "bottom_bar",
        title: "",
        config: 	{
      	broadcastPastEvents: true, // <= IMPORTANT to see past events
          mode: "week",
          instanceId: "basicCalendar",
          locale: 'nl-NL',
          maxEventLines: 5,
          firstDayOfWeek: 1,
          calendars: {
              url: "https://calendar.google.com/calendar/ical/private/private-code/basic.ics",
              name: "Name", // <= RECOMMENDED to assign name
              color: "Red" // <= RECOMMENDED to assign color
      Thanks in advance!
        sdetweil @redux703
        @redux703 see this post
        https://forum.magicmirror.builders/post/127508
        • R
          redux703 @sdetweil
          @sdetweil Thanks! This worked like a charm. Also had to add to normal calendar module
          • R redux703 has marked this topic as solved on
