    MMM-CalendarExt3 showHeader config option
    6 Posts 2 Posters 1.2k Views 2 Watching
      scottwalsh
      I use the MMM-CalendarExt3 module, and decided for my configuration wanted to display it without the header (in week view).
      Made the following modifications to make it into an option to turn the header on and off.
      Sharing it here as haven’t looking into how to contribute via git…
      --- MMM-CalendarExt3.js.org	2025-08-09 22:19:40.792525741 +1200
      +++ MMM-CalendarExt3.js	2025-08-09 22:22:25.620897641 +1200
      @@ -82,7 +82,7 @@
           skipDuplicated: true,
           monthIndex: 0,
           referenceDate: null,
      +    showHeader: true,
           customHeader: false // true or function
      @@ -755,7 +755,7 @@
             config: options,
             range: [boc, eoc]
      -    makeDayHeaderDom(dom, options, { boc, eoc })
      +    if (options.showHeader) makeDayHeaderDom(dom, options, { boc, eoc })
           makeWeekGridDom(dom, options, targetEvents, { boc, eoc })
           if (options.displayLegend) displayLegend(dom, targetEvents, options)
           if (options.customHeader) customHeaderDom(dom, options, { boc, eoc })
      S S 2 Replies Last reply Reply Quote 0
        sdetweil @scottwalsh
        @scottwalsh cant you use css to hide the header?
          scottwalsh @scottwalsh
          I have two instances of the module, and I only want to hide the header on one instance. If I use CSS, wouldn’t it hide it for both?
            @scottwalsh use the MagicMirror module classes option to define a special class to use in the css selector
            see the options here
            https://docs.magicmirror.builders/modules/configuration.html
            module:"...",
            position:"....",
            classes:"foo bar",
            config:{
            then use
            .foo
            or .bar
            instead of
            .CX3
            or use the module id in the css selector
            #module-id-string
            see the second link in my signature below about using the browser developer window elements tab to explore the generated html content, including the module id
              scottwalsh
              Thanks for the tips, will take a look tomorrow to see how would do it via CSS.
              Why would you recommend doing it via CSS? Turning the headers on and off as a config option feel more intuitive to me compared to using CSS to surpress them.
                @scottwalsh because this module depends on css to suppress lots of other content , so its natural, and doesn’t require code change in any version
