    Cal EXT3 - understanding transforming
    14 Posts 3 Posters 6.9k Views 3 Watching
      sdetweil @_V_
      @_V_
      all in one… there is only ONE eventTransformer, it has to do ALL the work for ALL events
      I used else if here… if it matched the first, there is no reason to check again
      eventTransformer: (ev) => {
           if (ev.title.search("Geburtstag") > -1) {ev.color= "#ff00ff"; }
           else if (ev.title.search("Arzt") > -1) {ev.color= "#ff0000"; };
      return ev;
      R 1 Reply Last reply Reply Quote 2
        rkorell @sdetweil
        @_V_ as you might have overseen you can not only check several conditions (as Sam (@sdetweil ) suggested) - separated by else or not but you can make several changes to the same event at one check.
        e.g.:
          if (ev.title.search("Restmüll & Papier & Gelber Sack") !== -1) {ev.isFullday = [true], ev.title = "Alle Tonnen", ev.symbol = [ "fa-regular fa-trash-can" ], ev.color = "fuchsia"}
          if (ev.title.search("Therapie") !== -1) { ev.title = "Sitzung", ev.symbol = [ "fa-solid fa-mug-hot" ], ev.color = "Forestgreen"}
        return ev
           			  }, // end Eventtransformer
        In the above example you can see
        • the modification of the color (as you already had identified,
        • the change of the kind of event (from “scheduled” to “Fullday-Event”)
        • the assignment of a different symbol (with font-awesome-symbols: double check their web-page, keep in mind that only the “STANDARD” (non-payed) versions will be shown in Magic Mirror) and
        • the change of the title of the event.
        Hope this helps.
        Good luck!
        Ralf
          sdetweil @rkorell
          @rkorell his issue is not knowing JavaScript language and syntax
            rkorell @sdetweil
            @sdetweil Yes :-)
            therefore I thought a detailed example would be beneficial …
            Warmest regards,
            Ralf
