    Cal EXT3 - understanding transforming
    14 Posts 3 Posters 8.4k Views 3 Watching
      sdetweil @_V_
      @_V_ transforming, you must ALWAYS return the event, modified or not
      • _
        _V_
        Hello Sam
        Thanks for the input.
        Ok now what would this search method mean for “title”
        Like, what is it the case of the EXT3 cal module?
        It says “title”?
        Anybody knows about my last question for icon change too?
        S 2 Replies Last reply
          sdetweil @_V_
          @_V_ from his readme
            sdetweil @_V_
            @_V_ what do you mean for title? We just searched title
            If you want to change it. Then do that
            ev.title=‘new string’
            Same with symbol
              sdetweil @_V_
              @_V_ you can change any property of the event
              • _
                _V_
                I get the idea but since Im quite new to this, I cant follow completely.
                Again the example
                eventTransformer: (ev) => {
                  if (ev.title.search("John") > -1) ev.color = "blue";
                  return ev;
                Now you told me, “search” is a look up in form of “if contains” - this means if it contains the value, it will give out a value bigger than -1 and the effect will be set; other wise it will return -1 and the event stays unedited, correct?
                This would also mean, I have to set up every possible event title class inbefore.
                If I want to change/assign a specific symbol is a thing I dont understand.
                I use the Iconify function from the module - do I have to put in a link to the desired symbol now or what is it I have to enter?
                I could also imagine that I have to download the symbols and put in a directory to make the module be able to access them?
                Thanks a lot
                  sdetweil @_V_
                  @_V_
                  If I search this field, and find ‘John’
                  Then
                  I change the event color
                  ev.color=
                  You could change to symbol the same way
                  ev.symbol=. Whatever symbol name
                  You are writing code here
                  The filter routine sees every event, one at a time
                  You can have more than one if stmt
                  Can use if else if else, use a switch /case logic block
                  _ 1 Reply Last reply
                  • _
                    _V_ @sdetweil
                    @sdetweil Sam good evening
                    I wonder how to set up multiple ev transformations in one config.
                    I got working
                    if (ev.title.search("Geburtstag") > -1) {ev.color= "#ff00ff"; };
                    return ev; },
                    But putting another one to it is puzzling me. I tried different methods, but cant get it done.
                    When I simply put a second complete command after the first, like this:
                    if (ev.title.search("Arzt") > -1) {ev.color= "#ff0000"; };
                    return ev; },
                    it will just negate the first applied effect from birthday and uses this effect instead on the named events.
                    Can you help me out please?
                      sdetweil @_V_
                      @_V_
                      all in one… there is only ONE eventTransformer, it has to do ALL the work for ALL events
                      I used else if here… if it matched the first, there is no reason to check again
                           else if (ev.title.search("Arzt") > -1) {ev.color= "#ff0000"; };
                      return ev;
                      R 1 Reply Last reply
                      Reply Quote 2
                        @_V_ as you might have overseen you can not only check several conditions (as Sam (@sdetweil ) suggested) - separated by else or not but you can make several changes to the same event at one check.
                        e.g.:
                          if (ev.title.search("Restmüll & Papier & Gelber Sack") !== -1) {ev.isFullday = [true], ev.title = "Alle Tonnen", ev.symbol = [ "fa-regular fa-trash-can" ], ev.color = "fuchsia"}
                          if (ev.title.search("Therapie") !== -1) { ev.title = "Sitzung", ev.symbol = [ "fa-solid fa-mug-hot" ], ev.color = "Forestgreen"}
                        return ev
                           			  }, // end Eventtransformer
                        In the above example you can see
                        • the modification of the color (as you already had identified,
                        • the change of the kind of event (from “scheduled” to “Fullday-Event”)
                        • the assignment of a different symbol (with font-awesome-symbols: double check their web-page, keep in mind that only the “STANDARD” (non-payed) versions will be shown in Magic Mirror) and
                        • the change of the title of the event.
                        Hope this helps.
                        Good luck!
                        Ralf
                          sdetweil @rkorell
                          @rkorell his issue is not knowing JavaScript language and syntax
                            @sdetweil Yes :-)
                            therefore I thought a detailed example would be beneficial …
                            Warmest regards,
                            Ralf
