    Cal EXT3 - understanding transforming
    14 Posts 3 Posters 8.0k Views 3 Watching
    • _ Offline
      _V_
      Hello again guys
      I am using the 3rd cal-mod from @MMRIZE and try to bring it up a bit more specific regarding styling.
      So the documention says:
      Transforming
      You can manipulate or change the properties of the event.
      eventTransformer: (ev) => {
        if (ev.title.search("John") > -1) ev.color = "blue";
        return ev;
      This example shows how you can transform the color of events when the event title has specific text.
      Would this mean, it looks up, if the events text is exact like the named text ( “John” in this example )
      OR the event starts with the word
      OR the event contains this word?
      Also I wondered, if I can specify the icon used for this event, besides defining the events color?
      Thank you very much and as always, regards from Germany
      S 3 Replies Last reply Reply Quote 0
        sdetweil @_V_
        @_V_ said in Cal EXT3 - understanding transforming:
        ev.title.search
        search() searches the string for the specified characters and IF those characters are found, it returns the position of the text in the string…(0= 1st char/start of string). if NOT found it returns -1
        this is a javascript string function
        there is also startsWith() and endsWith()
        search() = contains
        the code could have used includes()
        The includes() method of String values performs a case-sensitive search to determine whether a given string may be found within this string, returning true or false as appropriate.
        if you wanted case insensitive, you would do
        ev.title.toLowerCase().includes(‘john’)
          sdetweil @_V_
          @_V_ transforming, you must ALWAYS return the event, modified or not
          • _ Offline
            _V_
            Hello Sam
            Thanks for the input.
            Ok now what would this search method mean for “title”
            Like, what is it the case of the EXT3 cal module?
            It says “title”?
            Anybody knows about my last question for icon change too?
              sdetweil @_V_
              @_V_ from his readme
                sdetweil @_V_
                @_V_ what do you mean for title? We just searched title
                If you want to change it. Then do that
                ev.title=‘new string’
                Same with symbol
                  sdetweil @_V_
                  @_V_ you can change any property of the event
                  • _ Offline
                    _V_
                    I get the idea but since Im quite new to this, I cant follow completely.
                    Again the example
                      return ev;
                    Now you told me, “search” is a look up in form of “if contains” - this means if it contains the value, it will give out a value bigger than -1 and the effect will be set; other wise it will return -1 and the event stays unedited, correct?
                    This would also mean, I have to set up every possible event title class inbefore.
                    If I want to change/assign a specific symbol is a thing I dont understand.
                    I use the Iconify function from the module - do I have to put in a link to the desired symbol now or what is it I have to enter?
                    I could also imagine that I have to download the symbols and put in a directory to make the module be able to access them?
                    Thanks a lot
                      sdetweil @_V_
                      @_V_
                      If I search this field, and find ‘John’
                      Then
                      I change the event color
                      ev.color=
                      You could change to symbol the same way
                      ev.symbol=. Whatever symbol name
                      You are writing code here
                      The filter routine sees every event, one at a time
                      You can have more than one if stmt
                      Can use if else if else, use a switch /case logic block
                      _ 1 Reply Last reply Reply Quote 0
                      • _ Offline
                        _V_ @sdetweil
                        @sdetweil Sam good evening
                        I wonder how to set up multiple ev transformations in one config.
                        I got working
                        if (ev.title.search("Geburtstag") > -1) {ev.color= "#ff00ff"; };
                        return ev; },
                        But putting another one to it is puzzling me. I tried different methods, but cant get it done.
                        When I simply put a second complete command after the first, like this:
                        if (ev.title.search("Arzt") > -1) {ev.color= "#ff0000"; };
                        return ev; },
                        it will just negate the first applied effect from birthday and uses this effect instead on the named events.
                        Can you help me out please?
                          sdetweil @_V_
                          @_V_
                          all in one… there is only ONE eventTransformer, it has to do ALL the work for ALL events
                          I used else if here… if it matched the first, there is no reason to check again
                               else if (ev.title.search("Arzt") > -1) {ev.color= "#ff0000"; };
                          return ev;
                          R 1 Reply Last reply Reply Quote 2
                            @_V_ as you might have overseen you can not only check several conditions (as Sam (@sdetweil ) suggested) - separated by else or not but you can make several changes to the same event at one check.
                            e.g.:
                              if (ev.title.search("Restmüll & Papier & Gelber Sack") !== -1) {ev.isFullday = [true], ev.title = "Alle Tonnen", ev.symbol = [ "fa-regular fa-trash-can" ], ev.color = "fuchsia"}
                              if (ev.title.search("Therapie") !== -1) { ev.title = "Sitzung", ev.symbol = [ "fa-solid fa-mug-hot" ], ev.color = "Forestgreen"}
                            return ev
                               			  }, // end Eventtransformer
                            In the above example you can see
                            • the modification of the color (as you already had identified,
                            • the change of the kind of event (from “scheduled” to “Fullday-Event”)
                            • the assignment of a different symbol (with font-awesome-symbols: double check their web-page, keep in mind that only the “STANDARD” (non-payed) versions will be shown in Magic Mirror) and
                            • the change of the title of the event.
                            Hope this helps.
                            Good luck!
                            Ralf
                              sdetweil @rkorell
                              @rkorell his issue is not knowing JavaScript language and syntax
                                @sdetweil Yes :-)
                                therefore I thought a detailed example would be beneficial …
                                Warmest regards,
                                Ralf
